Question about Sony CDX-FW570 CD Player
Stereo wiring codes
I need stereo wiring codes for a 86 toyota pickup.
  • 253 Answers
If you take a 9v battery, and touch it to the speaker wires, you can find out which wire goes to which speaker, OR you need only 3 wires ( memory, power, ground) to power the radio, then you should be able to figure out which are the speakers, or attach a speaker, and use fader and balance to figure out which channell that is on the radio
Posted on May 15, 2009
Toyota pickup 94 model cant get spark plugs 2 fire replaced pickup coil igniter rotor buton wires cap coil fires plugs wont
I had to replace the magnetic pick-up sensor on the side of the distributor that tells the coil when to fire on my 86 truck. It was $80 and slips onto the distributor held on by the cap.
Mar 29, 2013 | 1994 Toyota Pickup
I understand that '86 4Runners were built on a Toyota pickup chassis. What model pickup was that? I'm looking for a trailer hitch, but catalogs don't list the '86 4Runners. They start at '87s. So I...
If what you say is true. The only pickup it could possibly be is the Toyota Pickup. CURT offers the 13086 hitch for the 84-95 light pickups. If there is a lot of rust, this is going to be rather difficult as the bolts mounting the bumper will more than likely need to be cut. I can't find any information confirming fitment, but i'm sure this is your best bet. Custom fabrication would be your only other option.
Dec 10, 2010 | 1986 Toyota 4Runner
My 86 Toyota 4x4 pickup will not start. Won't turn over, no click, won't start when jumped. All lights working fine and stereo will come one. Happened "all the sudden", as in it started in the...
try putting a female connector on the end of a length of heavy gauge wire, slide the connector onto the male one on the side of the starter (after pulling off the one already attached) and then touch the other end to the positive terminal on your battery. make sure it's out of gear. the starter will engage whether or not the truck is on. if it doesn't, your starter's dust. if it does you simply need to replace the connector that attaches to the starter (most likely), replace or bypass the button-thing behind your clutch pedal that needs to be depressed for starting (less likely), or you have some kind of ignition switch problem (unlikely because everything else works when you turn the key on.).
Nov 12, 2010 | 1986 Toyota Pickup 4WD
Does a 1994 Stock Toyota pick-up 2wd. Come with stereo wiring?
there is no wiring for a stereo system at all (toyota,along with all major makers, skimp on everything,allowing you to fit a system that,if you can afford it,will "fill the grand canyon with sound"
Apr 17, 2010 | 1994 Toyota Pickup
Trying to hook up a new stereo. Where can i find a wiring schematic for a 1994 toyota pickup?
Car Radio Constant 12V+ Wire: Blue/Yellow
Car Radio Ignition Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope this helps
Dec 10, 2009 | 1994 Toyota Pickup
Cant find fuses for gages or turn signals
Here is a few if you are still looking...
Jun 02, 2009 | 1986 Toyota Pickup 4WD
Oem clock for a 86 toyota pickup,
if you look in the dash where the clock goes, you will find the 4 pin plug for the clock taped off to the side with blue tape- they all had wiring for the clock, regardless of wether or not they were actually equipped with them.
Jan 12, 2009 | 1986 Toyota Pickup 4WD
1986 Toyota pickup stereo wiring COLOR CODES NEEDED
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Illumination Wire: Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Sep 01, 2008 | 1986 Toyota Pickup 4WD
WIRING DIAGRAM FOR 1988 TOYOTA PICKUP CAR STEREO
just use a volt meter and test around to find your powers and grounds. then look behind the speakers to find the wire colors and compare to behind the stereo
May 12, 2008 | Car Audio & Video
Sony CDX-FW570 CD Player Logo
201 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
