Question about Tech Solution TS-4500 Shredder
Paper jam. Ready lite comes on but shreder will not start shreding
I have a paper jam. The shreder shows a green lite in the on or reverse position but will not shred. I have been unable to get the paper out.
  • rlabaume1 May 17, 2009
    Thank you for your response. I appreciate the help.
  • Paulette Westbrooks
    Paulette Westbrooks Jan 18, 2014
    thanks a lot
  • 328 Answers
Common problem with paper shreds blocking the sensors on top and bottom of cutter asm. You may have to remove the top of unit to properly clean. When removing top, be very careful with the short ribbon cable. Lift top slowly and then reach under and disconnect from main board. Once top is off, you can cycle motor by hand and try to remove shreds with needle nose pliers. Of course, disconnect power first.
Posted on May 15, 2009
Qualcast manuals
Unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 25, 2014 | Office Equipment & Supplies
Without paper jam, the system is showing paper jam ? why ?
try to run Maintenance from windows control panel, also open all compartments on teh printer and look to see if there is a fragment of paper stuck there.
Jul 22, 2014 | Canon LASER SHOT LBP-2900 Printer
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Shows paper Jam on Canon 720 PC photo copier
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Nov 16, 2009 | Office Equipment & Supplies
Royal 9 x cross cut shredder wont go through even two pages thick
Put some shredder oil on the paper you are shreding...shred a number of sheets with oil on them so that the oil gets down into the cutting shafts/teeth.
Jan 12, 2009 | Royal Office Equipment & Supplies
Paper Jam in my all in one printer-scanner-copier HP PSC 2355
open the cover at the back of the printer that is provided to remove paper jam.remove the jammed paper and then off the printer turn it on again after few minutes and let in come to ready mode .it will take some time to come to ready mode as it will need to realign itself in proper position. once its in ready mode u can continue with ur work
Dec 17, 2008 | HP Office Equipment & Supplies
Paper Jam
Dec 17, 2008 | HP PhotoSmart C4180 All-in-One Color...
I have a SX102M paper shreder that wont shrede
It's the paper sensing microswitch. Wire a small toggle switch and drill a small hole for it on the far right side of the top housing. Just remember that the switch has to be turned off when you are finished shredding or the motor will keep running till it burns out
Nov 21, 2008 | Cross Infoguard Shredder SX102M
Shreder not turning on
where are the safety interlocks located??
Nov 14, 2007 | Office Equipment & Supplies
Tech Solution TS-4500 Shredder Logo
573 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
