Question about Hotpoint Aquarius WMA42 Front Load Washer
Machine dead after changing the brushes
We are having problems with our hotpoint aquarius washing machine...my husband changed the brushes...now the door light flashes every so often and basically the machine is dead...some one please help....we have checked the fuse in the plug and its not that.
  • 56 Answers
I presume you checked the motor plug,not sure if there is a cable running from the motor down to the door in this model to ensure the motor is stopped before the door can be opened,id check in this area because they can be troublesome,take out the door lock by taking the front lip of the door rubber and make sure it is closing properly,i wouldnt be looking anywhere else for the fault at this stage-hope this helps
Posted on May 15, 2009
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How do i change brushes on a hotpoint aquarius 900 clothes are still wet after spinning and i have been advised to change brushes
brushes? thats a good un! if its spinning fast its not brushes, it could be the water out pump though, or filter is blocked, even if you did try to change the brushes its no easy job to do, call a guy out to fix it,
Oct 20, 2009 | Washing Machines
Fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do i change the brushes on my wf250 hotpoint aquarius machine
your machine may have a 'brushless' motor. but generally hotpoint motor brushes are fixed with 2 screws and are in ablack plastic cover and can be seen if you tip your machine back against a wall and look underneath. the motor being at the bottom of the drum, you could remove them wuth a long magnetic screwdriver.
Feb 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wma50
The motor does not have provision for belt adjostment, it is self tensioning
To gain access to the brushes, you need to remove the motor from the washer.
Remove rear panel, remove belt, unplug motor lead, taking note which way the plug goes,undo screws securing motor, and lever motor back with a screw driver, remove motor and change brushes.
Feb 12, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
136 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
