Question about Husqvarna Garden
I am having some problems. it will run for about 30 seconds or less and then sputter out... wait a few min and it will do it again. if i manualy feed it fuel it will keep running, i have replaced the fuel pump, I have replaced the fuel line and there is no leaks
  • scott569 May 15, 2009
    ok let me get into more detail. its not a plunged carb. I checked the compression (130 psi per cylinder). the carb is very clean, I runs perfectly for the 30 seconds it runs, then it coughs a little and dies out and will not restart. plugs are good, coils are good...
motor1258
  • 6674 Answers
SOURCE: fuel pump not staying on 1993 k1500 350
Some GM products also incorporate the oil sender switch into that circuit for fuel pump, so that in case of an accident, engine shuts off, oil pressure drops, in turn, shuts off power to fuel pump. May be worth a look at what your getting for oil pressure, as well as checking switch/sender.
Posted on Feb 13, 2009
dennymulford
  • 1055 Answers
SOURCE: 2000 Grand am gt 3.4 dies out when driving
no its vapor locking losen up the fuel cap and leave it lose your vent line is prob plugged
Posted on Mar 04, 2009
dennymulford
  • 1055 Answers
SOURCE: Engine cranks, runs for approximately 30 seconds
you nee too take the carb apart and clean it!!!!!!!!!!!!!!
Posted on Apr 01, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
shadtremonky
  • 353 Answers
SOURCE: engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Posted on Jun 20, 2009
In the morning the truck start fine and runs fine.
check the alternator... battery isn't getting sufficient power from it. if tthe problem continues there will be chance of battery dead. duo to the less power supply from alternator, if we increase the rpm though the vehicle wont go faster and engine gets off. so my suggestion is please check the altrnator replace it if required.
Apr 12, 2017 | 2006 Ford Super Duty F 550 Drw
My 1983 ford motorhome starts fine, but when i try to drive it its like it runs out of gas.
possibly electronic ignitition module ... 30$ ... this drove me nuts i kept thinking it flooded, then wait 30+ min starts again for less than 3 min . good luck
May 26, 2011 | 1983 Ford Econoline
LT1550: runs for about 30 mins on 1/2 to 3/4 throttle. sputters and DIES!!!!! I have to wait a day or two before it would start again.
Try this:
When it begins to stall, loosen the gas cap. If the engine smooths out, clean the vent holes on the cap.
Gary
May 08, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Oct 10, 2009 | 1994 Dodge Ram
1991 Mazda MX-6 starts and it dies within 30 seconds or less.
Check to see fi your fuel pump is functioning, also change the fuel filter. I had this same problem on a 1984 626. While i waited for the car to restart fuel would seep into the line to allow for the enging to startbe that was it.
Dec 25, 2008 | 1989 Mazda MX-6
Htr shuts off after awhile and won't come back on till it's cooled down
I had the same problem with my heater. It was a cracked fuel line. I replaced the rubber hoses. On mine there was a pick up hose and a feed hose. They were dry cracked. Works great now. Hope that helps you out.
Nov 02, 2008 | Reddy Heater-30-55,000 BTU Variable
Philips 46pp9302 about 5-6 yrs old after 20-30 min. shuts off
Just posted this elsewhere:
Is the cooling fan running?
If not, the set may be designed to shut down after a few seconds to protect itself (and you).
Aug 10, 2008 | Philips 46PP9302 46" Rear Projection...
Garden Logo
89 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
