Question about Bosch AquaStar 125FXKIT-LP 125FX Liquid Propane Gas Tankless Water Heater w/ Hood
Bosch AQ 125XNG water heater burner frequently won't light
The ignition flame always comes on, but the burner will not light 75% of the time, and often only when we first turn on the highest demand tap in the house, the washing machine set to hot, before we can open another tap and expect hot water out of it. But not even that works much of the time. Sometimes I can get it to light by blowing with all my might into the pilot flame and jumping back before my hair gets singed, but that usually doesn't work either. I checked the battery voltage and they are over 1.4V so that doesn't seem to be the problem (instructions say only need replacement when below 1.2V). Replacing them doesn't always help anyway. But the "clicking" when the water is turned on varies greatly in speed. When it is slow, I know the burner won't catch. When it is rapid there's a much better chance that it does.
What gives???
    President:
  • 3,433 Answers
May be That we have something we can try. first, what doesn't work most of the time? Blowing with all you mite or jumping out of the way before your hair gets singed?
I think it sounds like you might have a maladjusted ignitor. Mispositioned. Its not in the gas path. Sometimes this happens as the tungsten ignitor wears down. That can be adjusted by repositioning the ignitor so it is in the pat of the gas. Just don't test as you go. Set the ignitor so the arc is about 1/4 inch long and about 1/4 inch away from where the gass comes out. Keep clear of the access hole. The longer it takes to ignite, the more gas build up there is. Have your exhaust vent checked. restriction keeps it from drafting and drawing enought air to balance the air gas mixed to ignitable.
Be careful and be safe
Posted on May 18, 2009
Just installed a 425 hn, the igniter clicks and the pilotflame goes on and off at the same rate as the igniter clicking. The main burners will not kick on. Checked all the electrical connections, checked...
I am not aquainted with the Bosch..... But it is a heater. I am going from past experience with gas furnaces and how the process works..... You said that you can get the pilot to stay on if you unhook the Main Gas Valve wire. Do you have 24 Volt power on that wire to Common? Does this have a Flame Sensor? Maybe it got damaged. Does it have a good ground from the burner to the ignition control module? Does that wire to the electro valve go into a plug that plugs into the ignition control.... Maybe that pin is not making contact to the board. Hope this helps If no one else answer right away repost Or call and see if you can get Tech support from Bosch..... I know how frustrating it is you buy something brand new and it doesn't work
Feb 01, 2011 | Bosch 425HN NG Tankless Water Heater
Sometimes it doesn't light at all other times during use the hot water goes off and the box keeps flashing green as it continues to spark
it sounds like the flame sensor is dirty or faulty. when the pilot lights the flame sensor rod recognises the flame to allow the main gas valve to open and ignite the burners. you can clean the flame sensor with some steel wool or sandcloth
Dec 29, 2010 | Bosch & Tankless LP Hot Water Heater
I have a Bosch natural gas tankless water heater and the problem I have is that the burners do not ignite until there is ,8 of a gallon of water flowing through it. Thus, once you have suficent hot water,...
Hello Larry,
Unfortunately nothing can be done about the minimum flow for activation.
However, your heater should have a flow control dial that you can turn all the way clockwise which will reduce your activation rate to about 0.5 gal. but that's the absolute lowest.
If the reason is to conserve water than that's about all you can do.
However, if its because the water is too hot and your mixing in cold which is increasing the volume of water you are using, then you should have a burner or flame control, if its a dial turn clockwise for less flame on the burner or the heater may have a slide control which sliding more to the left will lower the burner flame.
Don't forget water valve maintenance in your manual, follow instructions for a water valve rebuild to restore performance to the heater.
That's about it.
Dec 08, 2010 | Bosch & Tankless Water Heater
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and...
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Apr 25, 2010 | Bosch & Tankless LP Hot Water Heater
Hi Our gas water heater is not igniting
you need to replace the thermocouple its an electronic device that keep the gas flowing . the pilot light is always on and the thermo couple controls the flame. if it goes bad the flame goes out and the burner wont come on to heat the water, they are easy to replace and available at all home depot or a lowes kind of store.
Dec 01, 2009 | Water Heaters
Electronic water heater burner often won't light tho pilot's on
it sounds like you pilot lite is to far away from the burner, make sure that the burner is sitting in it;s purch, look thru the site glass it can be moved by hitting or bumping into the out side of the gas tubes on the outside of water heater, if not, the burner assembly may have soot on it. you might also want to make sure the filters are not clogged on the shut offs that will give it less pressure then it needs to make the unit come on,, write me , gary1121@aol.com
May 15, 2009 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch AquaStar 125FXKIT-LP 125FX Liquid Propane Gas Tankless Water Heater w/ Hood Logo
598 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
