Question about Refrigerators
Zanussi frost free fridge freezer leaking water at back
I purchased my frost free zanussi fridge-freezer 20 months ago from Comet. It has now developed a leak at the back near the bottom left, where there's a small white box attached to the fridge (I don't know what the purpose of the box is as it isn't specified in the manual).
I'm hoping it's not a technical fault, so far I have tried cleaning the dust from the back and increasing the freezer temperature but to no avail.
Any advice would be much appreciated.
Thank you!
  • 8 more comments
  • khadejah_beg May 16, 2009
    Hi bobicehouse,
    The model no. is ZNB4051S.
    Many Thanks :)
    I already have a copy of the manual, but the manual has no information regrading my problem. As I mentioned above, it doesn't even tell me the name of the part which I have detected the leak is coming from - I just thought that would be a good place to start.
    Thanks anyway
    Yep its a white box attached to the bottom left of the fridge. There is water definitely coming from the electrical box, and ive checked for moisture along the defrost tube just above, but there is none.
    Why would there be water leaking from the electric box of all places??? (*confused*) I will try and remove it and let you know the outcome :)
    Ok I've removed the electrical box and there was a lot of water accumulated on top of it. The defrost water tube exits into teh evaporator tray which is dry. However there is mositure just above the area where the electrical box was. There is no obvious source. Once again, confused!
    No the exit point is dry.
    You mean its missing insulation? How can I check for this and is this easily solved?
    Ok so are you suggesting that the electrical box hasn;t been insulated? I'm not sure i understand how this would cause water to leak.
    Where woud I insert the foam? And also would this come under a maufacturing fault?
    Thank you so much for your help. Please could you explain how exactly this would cause a leak.
  • Robert Moller
    Robert Moller May 11, 2010
    Please post a model number.
    Guru:
  • 1,524 Answers
Here is a link for your unit's manual: http://www.serviceforce.co.uk/pdfs/U30164.pdf
Posted on May 16, 2009
  • 8 more comments
  • Robert Moller
    Robert Moller May 16, 2009
    Sorry, let me see what I can find. Some manufacturers are hesitant about posting service even for technicians.
  • Robert Moller
    Looking at the back of the unit is this on the left hand side attached to the refrigerator ?
  • Robert Moller
    I was able to blow up the diagram. That is the electrical box and the defrost water tube exits just above, so check to see if it has cracked. Unplug the unit and see if you can undo the box to see if there is any moisture accumulated.
  • Robert Moller
    Look where the tube exits and see if a leak is present.
  • Robert Moller
    Again look at the exit point of the tube, it may be weeping out.
  • Robert Moller
    The area above the box may have an insulation void.
  • Robert Moller
    They use an expandable foam and it might have missed Hardware stores carry it. You drill a hole insert nozzle and pull the trigger. Just be very careful.
  • Robert Moller
    In case you are wondering :http://www.dap.com/product_details.aspx?...
  • Robert Moller
    Not the electrical box rather the cabinet. You could call the authorized service and have them look.
  • Robert Moller
    Cold refrigerant lines going through the inside of the cabinet and warm ambient air. The insulation helps ****** condensation however a void would cause tis condensation to be excessive and it exits where ever there is any type of hole.
Zanussi frost free fridge freezer we have had two zanussi fridge free freezers in the past month that do not drain away the water from the fridge. The water builds up under the vegetable drawers and...
this is a common fault with them, when packing them some of the packaging blocks the pipe. if you use a net curtain thing that hold up the net curtain push it down the hole up and down a few times then look at the drain away at the bottom of the fridge take the bits out. should be fine then. it happen alot and to deferent makes and models.
Sep 16, 2013 | Refrigerators
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Zanussi Refrigerators
Our Zanussi fridge is frost free type. Last week, the thick ice on the fresh food section of fridge (upper part) was melted by itself and leak the water everywhere. After we cleaned it out, the fresh...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Zanussi ZEBF250W Bottom Freezer...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Refrigerators
Frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Dec 30, 2008 | Freezers
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
LARGE WATER LEAK ON FLOOR
the reason is probably that the drain hole in the freezer (i assume this is a frost-free type) is blocked. take off the rear panel of the freezer and you will probably see a block of ice at the bottom. melt off with a hairdryer and free the drain with hot water making sure that water flows freely away
May 06, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
1,530 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
