Question about IBM ThinkPad T20 2647 Notebook
Thinkpad T20 won't accept memory upgrade
My T20 has 256MB memory and I want to upgrade to 512MB. I have bought two sets of chips - PC100 and PC133 and neither works. No combination of slots or memory cards work either. The only thing that boots are the two 128 MB PC100 memory cards that came with the machine. Is there some switch I need to change in BIOS? Any ideas? The machine runs Ubuntu nicely and I would like to add more memory to increase response time.
  • 1 more comment
  • Anonymous May 15, 2009
    the old memory is IBM and the 256 pc100 chips are not marked and the the 256 pc133 chips are Kingston.
  • Sphynkter
    Sphynkter May 11, 2010
    What brand, model, and size RAM did you buy?
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats new memory brand and model? and old one too?
    President:
  • 415 Answers
According to ibm
you are allowed only pc100 memory with a maximum of 512mb.
when handling memory make sure you are grounded before touching any memory chips.
try getting another set of 256mb chips and grounding yourself before installing them.
Mark
Posted on May 15, 2009
  • Mark Gough May 18, 2009
    It doesn't matter the ibm t20 will only accept pc100 memory.
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Installing a 512mb PC133 memory module in a t1090 emachine. The pc wont recognize the module and wont boot nor go into post. Switching back to the original two 128mb modules and the pc works normal. Is...
Hi there
Your t1090 will only accept a maximum chip size of 256Mb and so it will not accept the added the 512mb chip as it cannot handle it. 512 is the maximum size of RAM for this machine but unfortunately you cant put it in in one go
Jul 03, 2010 | E-Machines T1090 PC Desktop
T22 Doesn't boot on Memory upgrade
First make sure the memory is the same PC 100 , then make sure the chips are fully seated. and try rebooting computer. If you mismatch the Dimms the memory wont be recognized by the computer.
Sep 02, 2009 | IBM ThinkPad T22 2647 Notebook
Can't upgrade memory
According to the user manual for your laptop, it can only support pc-100 memory. If your going to upgrade your memory just make sure you use pc-100 and also the max amount of memory is 256mb in each slot so you would be maxed out at 512MB.
You can verify the info from this link from Dell:
http://support.dell.com/support/edocs/systems/latc600/en/ug/features.htm
May 23, 2009 | Dell Computers & Internet
IBM ThinkPad T22 Series (Type 2647) memory upgrade
Hold on a second.. I have fixed a number of T21's and I recall that these units are super anal about the type of RAM they use. I am pretty sure that they require PC100 and will not accept PC133.
One second.... Ok, I just opened up my T21 and it has FRU 20l0255 which is PC 100. Here is a link to the specs. I have tried using PC133 and the same think happens - just does not boot. Nothing.
May 16, 2009 | IBM ThinkPad T22 2647 Notebook
Can PC100 be substituted for PC133?
No they are not interchangeable normally. If by some chance your motherboard supports both then if you mix them the faster chip will run at the speed of the slower chip. You might be able to find PC 133 at kingston.com, or crucial.com. They will tell you exactly what RAM is compatible for your system if you use their memory finder tool. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | Dell OPTIPLEX GX240 P4 1.7GHz 256MB 20GB...
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Since this is an older machine, the performance can't be boosted very much. The maximum performance you can get from this machine is 1ghz processor, with 512mb RAM. The 1ghz processor is the biggest processor that is compatible, and unfortunately, the system is base on a 100mhz frequency rating, so PC100 memory is the only compatible memory available. The maximum chip size in PC100 is 256mb, they just don't make them any bigger, so 2x256mb=512mb RAM. As far as the hard drive, it is an IDE drive, and you can get an IDE drive up to 120gb. These are very good and durable machines, just slow, so if you can deal with the lower level of performance, this machine will last years. Also, these are upgradeable to XP pro, but not Vista.
Sep 04, 2008 | IBM ThinkPad T22 2647 Notebook
Ibm thinkpad 2647
Your limited with the T20 series, the biggest you can go is 1ghz. Try the Pentium M chip, make sure that it's the same mhz (frequency) that's in it now, the board frequency matches the processor frequency. (either a 100 mhz or 133 mhz, you can tell by what memory it uses PC100 or PC133)
Jun 09, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
351 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
