Question about Car Speakers & Subwoofers
Wanna make my suv da best in the area
Need advise on wut i need to make my suv the best in the area! wut brand do i need to put in my 2005 expedition to make it knock pictures off the wall! i want you to hear me coming a mile away! thanks for your time
Re: wanna make my suv da best in the area
If you're going for loud SQ then go with 2 JBL W15GTi's in ProBox's SuperBass box for 2 15's. If you just want SPL then get 2 15" Cerwin Vega Stroker's or Stroker Pro's in the same SuperBass box. Check out the box at With either setup, you won't even won't be able to sit in the Expo
Posted on Feb 15, 2008
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Go here
Posted on Feb 13, 2008
0 characters
3 Points
How to build a box for my 2 Lanzar Max 12d subs to get real deep low bass
If you have a spec sheet as far as volume and any trunk dimensions I can design exactly what you are seeking.
Jul 21, 2012 | Lanzar MAX12D Car Subwoofer
My car was in an accident. I need to syphon the gas in order to put in my other car so I can drive that car to work. I cannotseem to syphon it, the tank seems deeper than syphoning tubing. I have a 2005...
You can't siphon from car to car you will need a container, make sure that when you are sucking if you are using your mouth which is not advisable that you are in a position that is lower than a tank otherwise it wont work.
May 18, 2011 | Car Speakers & Subwoofers
I need to find out if my 97 ford expedition has a amp and a subwoofer factory and if so where is it located
97 Ford Expedition's came with two types of systems. With and without the MACH audio system. This can be determined by looking to see if there is a factory sub located on the passanger side rear side panel in the cargo area. If there is a sub there its the MACH audio system and the amp is located behind the same panel.
May 15, 2011 | Car Speakers & Subwoofers
What are the color scamadics for a 2005 ford focus sterieo wire diogram i need to splice into it
it is highly recommended that you do not splice into your factory wiring harness. the best solution i can give that will save you time and money in the long run, is to go to walmart. back in the automotive section ther will be some radios and such, around that area is the proper connector for your focus. if you cant find them, feel free to as an associate
Aug 24, 2010 | Car Speakers & Subwoofers
Where is best location to mount speakers besides trunk and trunk deck & doors?
Kick Panals are good, boxes are expensive though as they must be custom fit. Dashboard mounts, prolly only for componant speakers not subs. But if you wanna add speakers, you can always put more in the doors, trunk, or trunk deck to. Or replace your factory trunk deck, or door panals, and customize them to fit as many speakers as you like, have fun with it..
Oct 08, 2009 | Car Speakers & Subwoofers
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
3 kicker CVR12 Car Subwoofer to a amp tsunami 1100 watts digital i wanna if i can bridge the amp to the 3 speakers and how can i connet the wires from the poss to nev ????? please help PePe
The only way you can do this is if the amp has a min of three channels. you will need to bridge each speaker seperately. With that much power, attempting to bridge all three subs together will cause the amp to over heat and possibly blow. email me the specs of the amp and subs and i will give you the best advise
Feb 23, 2009 | Kicker CVR12 Car Subwoofer
I need help
Put this in google -- ported box software
Now, you will need multiple specs for your subwoofers to figure out the correct box size and port diameters/length.
Also, other calculations like the resonant frequency of the vehicle you are putting these in and numerous other issues. Seriously, is the wrong place to get this answered. Teams spends tens of thousands of dollars and years perfecting their vehicles to compete. Go to a good audio forum and ask this question there. You will receive ALOT better help and you can interact with some very knowledgeable people about your competition wishes. Good luck and have patience!!
Jan 12, 2009 | AudioBahn DUB200 Car Subwoofer
Car Speakers & Subwoofers Logo
158 people viewed this question
Top Car Speakers & Subwoofers Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Car Speaker and Subwoofer Expert? Answer questions, earn points and help others
