Question about Dishwashers
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I have a Kenmore Ultra Wash Quiet Guard 3 dishwasher.  The Quick Rinse light keeps blinking, and none of the other buttons work except for the Cancel/Drain button.  When you push the Cancel button, the 4 hours light turns on, but it doesn't do anything else.  How do I reset the buttons?  I have tried all the sequences found on this website (Hi Temp Scrub then Sani Rinse and also Hi Temp Scrub then Air Dry), but none of them worked.  I have the following buttons available:  Smart Wash, Pots Pans, Normal Wash, China Gentle, Quick Rinse, Hi Temp Scrub, Sani Rinse, and Air Dry/Lock On - along with Delay Hours, Cancel/Drain, and Start.  Please help!  Any advice will be much appreicated.  Thanks!
  • 2 more comments
  • Anonymous Nov 04, 2007
    I have the exact same problem. Cannot use any of the buttons...quick rinse just keeps blinking ' red light'.
  • Mary1967 Jan 21, 2008
    I have the same problem . Sani rinse keeps blinking and I cannot reset it.
    any solutions?
  • jbyrnes Apr 24, 2008
    We have the same problem but now it is to the point that none of the buttons work.
  • Anonymous Dec 02, 2008
    Please someone help us i have the same problem and no solutions.
    Problem Solver:
  • 5 Answers
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Posted on Sep 12, 2012
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
  • desplinto Dec 22, 2010
    try taking off the cover to the circuit panel behind the control panel.... there will be a couple of holes behind the circuit board which is held in by a couple of screws you shouldnt have to disconect any of the connections just move the board to the side.. spray moisture free canned air in the two holes...
  • Alison Grainger Oct 08, 2013
    to get to the circuit allthe screws around the door need to come out and the inside panel taken off?
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Ultra Wash Quiet Guard 3 problem
Thanks Munkee,
I started having this problem, blinking green light,  three days ago with my Kenmore QG3 and finally was tired of not being able to use my dishwasher. I've had it for three years with no problems until 3 days ago. You solution, use of commands, really helped and no money wasted on tech assistance. Thanks again!!
Aug 20, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
3,857 people viewed this question
Top Dishwashers Experts
