Question about HP LaserJet III Printer
Printing problem I have an HP LaserJet III. I inserted a refilled cartridge several months ago. It has been printing fine until now. Today, after several paper jams, there is a blank spot, about one-third of an inch wide, down the center of the page.
  • 11,896 Answers
You will need to clean cartridges and printer head with cotton swab and rubbing alcohol. Some printers have a self-cleaning diagnostic setting on them.
After thourough cleaning, print test page and use alignment if necessary.
Posted on May 15, 2009
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
I have replaced the toner cartridge but now it keeps saying "no print cartridge", I have taken it out and back in several times, turned it on and off several times but still says no print cartridge...
I just had a customer with this problem. Turns out they had a paper jam. 1 piece of paper from the paper tray was about 1/3 of the way up the paper path (had some ink on it). But it was stuck. They should have had a paper jam error but instead had a "no cartridge installed" error. Go figure.
Jan 13, 2010 | HP Laserjet M1319F Laser Multifunction...
White line
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps. I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
Jun 03, 2009 | HP LaserJet 3055 All-In-One Printer
HP Color Laserjet 1500L doesnt always print yellow
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP LaserJet 1500L Color Printer
Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Nov 07, 2008 | HP LaserJet 4 plus Printer
Printer wont print
Did you tried the testpage via PC or did you use the built-in testpage, starting with the printers buttons ?
Do you use refilled cartridges ?
Sometimes these cartridges need to be "resetted" after refill, what some refillers do forget.
Do you know if the drum is ok ?
What errors are displayed ?
Paperjam warnings can also come from the sensors for the paper.
Sep 09, 2008 | HP LaserJet 2605DTN Color Printer
HP LaserJet 1100 not printing
Firstly PRESS THE BIG BUTTON
Secondly if this doesn't work remove toner cartridge and look inside there maybe a piece of paper in there.
Thirdly Remove paper look down the paper feed entrance check there is no paper there.
Finally Replace toner cartridge.
Hope this is of help and please rate me
Cheers J
Dec 29, 2007 | HP LaserJet 1100 Printer
HP LaserJet III Printer Logo
113 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
