Question about Corel WordPerfect Office X4 Professional Full Version Volume License for PC
In wpx4 I switched printers and now my button
In wpx4 I switched printers and now my button is greyed out
  • 24 Answers
What button is greyed out?
If the print button, try goint ot File, Print and doing it there.
Try File, Page Setup
Posted on May 26, 2009
Hp printer
common problem on this equipement
do try this if you already cleaned head contact on cartridges with no success
INSTRUCTIONS:
1. Simultaneously press both the X button and the power button and hold
2. (NOT simultaneously) press BLUE button then GREEN button then GRAY button (in that order)
3. using blue (or grey) button, scroll-seek to the "information menu" - press OK button
4. press grey button once for "checksum for relock data input" - press OK button
5. press (X) repeatedly until you return to the normal main menu
6. PRINT
Mar 31, 2014 | HP PhotoSmart Office Equipment & Supplies
When I try to print in grey scale on my HP 8150, it starts out in grey, then switches to a purple-blue with grey scale stripes in it. This is a new problem with this printer, which has always been great. ...
i think there will be also one option use only black cartridge
that will solve ur problem
actually when it print in gray it uses all colour and then print in gray
Aug 07, 2013 | HP Photosmart 8150 InkJet Printer
How do I clear error message C-3821 for the Konica Minolta bizhub C253
HOLD THE UTILITY KEY WHILE SWITCHING ON THE POWER BUTTON INSIDE THE DOOR WHERE THE TONER/IMAGING UNITS GO, U WILL NEED TO HOLD IT FOR A COUPLE OF MINUTES UNTIL THE SCREEN GOES GREY
Jun 08, 2012 | Office Equipment & Supplies
Print cartrdge not detected error message
you need to refill the cardrides, u must know that the cartridges have a cip and must reset.
For reset u can try this press the CANCEL and POWER button at the same time, enter Special Key Combo after that press BLUE, GREEN, GREY button in sequence, the Support Menu will display, keep pressing GREY button to highlight Reset's Menu, Press GREEN button when Reset is highlighted, press GREY button then select Partial Reset printer will be reset. I hope to work good luck
Oct 12, 2011 | HP Photosmart C4580 All-in-One InkJet...
My CX4800 Printer language is in German. How do I switch to English?
1. Press the cancel and power buttons at the same time, while the printer is on.
2. Press the blue, green and gray buttons (in this order)
3. Change the menu options with grey button until you get to the "Resets" menu.
4. Press OK. "Country and Language reset" displays.
5. Press and hold OK for approx 2 seconds, then release. The printer will turn off.
6. Start the printer again - it should ask you to select language.
Feb 25, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Paper jam - hp c4380
Make sure that there is no paper stuck inside the paper, try cleaning the rollers, if the issue stil persit perform the below steps. Reset the All-in-One to the factory default settings by using these instructions: 1) Press ON and CANCEL buttons simultaneously 2) Display reads ?Enter Special Key Combo? 3) Press BLUE button, Green button and Grey button 4) Press Grey button continuously until "Resets Menu" is displayed. 5) Press Green button. 6) Press Grey button until "Semi full Reset" is displayed. 7) Press Green Button. This should resolve the issue.
Sep 27, 2009 | HP Office Equipment & Supplies
Toner light flashes
wow, yes.. press the Grey button on the side and the printer front mouth will open, than press the Grey button on the bottom left side down and take out the cartridge by pulling it with the handle....
Sep 10, 2008 | Lexmark E330 Laser Printer
My x1240 scans but does not copy or print. What do you suggest?
You will need to do the following diagnostic tests to determine the exact cause of the error:
· Remove the ink cartridges
· Perform the self test (test B below)
· Test the ink cartridges
A. To remove the ink cartridges:
Switch the printer on by pressing the green button.
Open the front cover of the printer. The cartridge carrier should move to the center of the opening.
Remove both cartridges.
If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand.
Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer.
Inside the printer, locate the silver metal carrier bar on which the print carriage slides.
Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion.
Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening.
Now pull both cartridges out.
B. To perform the self-test:
Disconnect both the power cable and the USB or parallel cable.
After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.)
Turn the printer off by pressing the green power button.
Hold down the grey paper feed button.
Turn the printer on by pressing the green button.
After the printer begins to feed paper, release the grey button.
Once the paper exits the printer, press the green button to turn the printer off.
If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. Please contact our Technical Support Centre for your service options. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below.
C. To test the ink cartridges:
Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place.
Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step.
Turn the printer off using the green power button.
Hold down the grey paper-feed button.
Turn the printer on using the green button.
If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly.
Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly.
If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase, or contact our Technical Support Centre.
IF u have problems u can use this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Mar 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Hp color laser jet printer 3000n
Try this. BTW, the Button with the "Check Mark" is the Enter button on this.
1). Switched the printer off.
2). Press and hold Enter button while turning the printer ON until CONFIG LANGUAGE appears in the Display.
3). After the power-on self test, lang=English (French, in your case) will appear. Press + button until the desired language (English) appears in the display.
4). Press Enter button to save your choice. An asterisk (*) will appear next to English to indicate it is now the default.
5). Press Online button. The On line indicator will be lit, and display messages will now be in English (you selected).
if that doesnt work try this
press...
green enter button once
right grey arrow button once
green enter button twice
then grey arrow button on right or left of green enter button until you see the language you want.
Select by pressing green enter button
Finished.
Jan 10, 2008 | HP Color LaserJet 2600n Printer
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
Corel WordPerfect Office X4 Professional Full Version Volume License for PC  Logo
166 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
