While running the machine started slowing down, then regained speed and worked as normal, slowed down and then stopped. Still has lights on the unit so it has power. Have tried a different outlet both for power and for the vacuum. No change.
SOURCE: The power paw on my vacuum machine is not working.Eureka ez kleen
The filter is not the reason it's not working. Take out screws and open Power Paw, remove fur from the roller brush on the right side, there is a small gap where fur winds around tightly, cut off with scissors or pull out with a small toothpick.
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
SOURCE: Eureka central vac 's power stopped won't start again.
I took to dealer I bought from . He examined it. The motor is gone needs new one. Thanks, Ann
SOURCE: Eureka 5841 upright vacuum cleaner quits running,
The motor is running hot and causing a emergency shutdown. It is either clogged somewere or the motor is bad check for cloggs first then if none are present you will have to replace the motor. Depending on the original price of the machine if the motor is bad you may be better off buying a new machine.
SOURCE: Eureka altima stopped power mid vaccuming, have changed outlits
make sure all your filters are clean,try to turn the brush roller by hand a few times if it turns real freely then the belt is broke.if it is reall hard to turn then you have something wrapped around the ends of the roller where the bearings are.your motor guard might be keeping it from running because it got too hot take the brush roller out and the belt let it cool down for 20 minutes then try it without the roller and belt.you should be able to take the ends of the roller off by just pulling out on them so you can remove what ever is in there
