Question about Hotpoint WMA46 Front Load Washer
Select a program , i makes the normal noise , but nothing happens
Eventually all the lights on the right hand side flash one after another (like the lights on the front of Knight Rider !) and the noise / motor stops.
I have tried most settings, rinse and spin , wash cycles etc , but always ends up like this !
Hi did you find a solution? as mine has just started doing exactly the same!
Posted on Jun 27, 2010
Dodge grand caravan when I turn my right turn signal on its normal then it will flash on the left side 3 times then it goes back to the right normal then the left side will flash 3 times again then it goes...
make sure each of the light bulbs on all signal lights, park lights, running lights, brake lights.
if they do --
pull the flasher relays and replace them.
Dec 17, 2014 | Dodge Grand Caravan Cars & Trucks
When i turn my steering to full extend either to right hand side or left, like turning my car in u turn...some noise is coming ..
the noise, like grinding or squeeling, is the power steering pump clutch,it is normal and nothing to worry about,(actually, its the fluid,bypass valve,that makes the noise)
Nov 06, 2010 | 1994 Toyota Camry
HP 5600 series Lid won't close properly so can't get anything to print. when I start to try to print the power button and the ink low button both flash but its not short of ink. If I press the resume...
On the HP5650 there is a switch on the right hand side at the top. The switch is flush with the inside surface under the cover. A tab on the right hand side of the cover is supposed to depress this switch telling the printer the cover is closed. If the cover is warped (mine was) or if the tab has broken off, you can manually depress the switch with a pen-point (or just hold the cover at that point) to get the printer to activate.
May 02, 2010 | HP DeskJet 5650 InkJet Printer
Hyosung GT250R indicator not working
It sounds like:
1) One of the wires that takes power to the right hand turn signals is shorted to the chassis.
2) One, or both, of the right hand turn signal bulbs is burnt out.
3) The turn signal switch has failed.
Nov 18, 2009 | 2005 Hyosung GT 250
Bosch Classixx 1200 red wash light flashes but doesn't start
Could still be the water inlet valve. What you need to do is pull the washer out where you can get to the valve and the plug. Unplug the inlet valve and start the washer and when you start it as normal check the volts of the plug and see if its 110 if it is you know that the valve is getting power to open but not,replace the valve. If you dont get any voltage then it could be the relay or control board
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Noise from drum
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this safe too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only .I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one cause I suspect.
Thank you for contacting Fixya.com
Aug 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
When washer agiates it makes a loud squeaking noise, what can it be?
Aug 30, 2009 | Washing Machines
1993 Dodge Shadow...left turn signal won't flash
If the fuses are good and the front and rear bulbs are good, change the flasher for the turn signals, even tho the right is working. If that doesn't fix the problem, it might be in the turn sgnal switch on the steering column.
If both bulbs are good for the backup lights and fuses are good, then the backup light switch, which is screwed into the side of the transmission has to bad.
Apr 12, 2009 | 1993 Dodge Shadow
Flashing beeping light
This may sound too simple but make sure the lense is on there flush and locked. Sometimes it can go on crooked.
Mar 03, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
Hotpoint WMA46 Front Load Washer Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
