Question about Amana ARGS7650 Electric Kitchen Range
My Amana ARGS7650
Hello: The sensory board behind the keypad has come loose. It just sits there about 1 inch behind the palstic pad.
How do I access it and secure it back so it functions?
Thank you CB
  • banker1 Oct 16, 2007
    Hello- did you get my reply at 8:15 this morning.
    thank you
  • banker1 Oct 17, 2007
    please read my post
  • 290 Answers
Turn the power off to the range.
If you have the duel fuel model, remove the burner knobs and remove the screw behind each knob.
Open the oven door and reove the four screws that hold the bottom of the control panel to the range.
The panel should pull out and down at the bottom.
You will probably find the ears that hold the board have broken. Some of these models only used two screws to hold the board to the panel, which left two ears that you can put the screws in to fasten it back in place. If all four ears are broken, I have used flat washers under the screws to fasten it back if there is enough of the ear left for the washer to catch.
Posted on Oct 16, 2007
  • Michael  Lindley
    Michael Lindley Oct 17, 2007
    banker1, I have not recieved a response. If the directions I gave you do not apply to your range, I will need the complete model number. There should be some letters after ARGS7650 and then a string of numbers after that starting with a P. There are over 50 different versions of the ARGS7650 model. I gave the directions that are for the models similar to the picture you have it listed under.
    Thanks/Mike
  • Michael  Lindley
    There must be some kind of technical trouble somewhere. If you are posting more information, it isn't making it onto the thread I can see.
    Thanks/Mike
SOURCE:
The code on the control panel says "F1". What should I do
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Amana Ovens
We had a power loss and when the power was restored the readout for my range said F1. The burners work, but not the oven.
Hi
Daniel
Aug 29, 2011 | Amana Ovens
F-1 is showing on the panel and making a beeping noise and the oven won't come on.
Hi
Daniel
Aug 09, 2011 | Amana AES3760BAS stainless steel Electric...
The display is flashing an F1 problem
Hi
Daniel
Aug 04, 2011 | Amana DCF3315A Gas Kitchen Range
Hello, I have a kenmore range with a F-1 code, what is my problem. Do you have a list of f-code I can have for future reference? Thanks
Hi
Daniel
Aug 01, 2011 | Kenmore Ovens
Starts on own F2 appears
Unplug the oven for few minutes, say 30 minutes and then turn it on.If the problem persists, you need to replace keypad. This is a quite easy repair. You would take the grill off along the top over the door. Once off you should see the screws holding the control panel in place. Remove these screws and remove the control panel. You will now have access to replace the part. Please be aware that the unit stores lethal voltage even when unplugged.
F2 means the touch pad has failed, the manufacturer recommends you replace the touch pad and if this fails to clear the problem replace the control board.The manufacturer recommends this but the problem normally relates to the touch pad. The control board sits just behind the touch pad so is accessible by removing the control panel.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 14, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirpool model# RF385PXGN (electric) error code F2 E0 The failure/error display codes says replace control. What is control ?
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
Electronic key pad does not lite up top igniter are working fine
1.Loose wire to control board
2. Defective control board
3. This requires interactive troubleshooting
Apr 06, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650 Keypad has no power
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Dec 01, 2008 | Amana ARGS7650SS Gas Kitchen Range
AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
May 21, 2007 | Amana AEW4530DDS Electric Single Oven
Amana ARGS7650 Electric Kitchen Range Logo
202 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Paul Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
