Question about Garmin iQue 3600 GPS Receiver
The oiption of "Stay on in cradle" doesn't work
Hi
Although I check the option in Preferences=>General it doesn't work and when the Palm is in the cradle, it shuts off after 3 minutes.
Any idea?
Thanks
  • 174 Answers
Null
Posted on Jan 28, 2008
SOURCE:
Take pageset off my screen
Go to control panel and navigate to Programs and Features. Uninstal pageset
Nov 07, 2013 | Computers & Internet
YM 9.0 Main Window pop-up
Uncheck the option to sign in automatically in General
> Messenger > Preferences > General - make changes > OK
Oct 24, 2008 | Yahoo Messenger
Palm v
the lightning bolt indicates that the battery is being charged. I will stay on as long as it is being charged either in the cradle, or using an external charger. If it stays on after it is removed from any external power source, there is a problem with the unit and it needs serviced.
--Randy Miller
Aug 25, 2008 | Palm TX Handheld
Pictures not being displayed treo 755P
From your web browser, press your menu button, then go to "Options", select "Preferences", select the "General" tab, at the bottom Un-Check the box next to "Don't download images!
Hope this helps,
Glenn
Jun 17, 2008 | Palm Treo 755p Smartphone
Palm M515 hot sync problem
Hi you could either have a problem with the lead witch is the cheapest problem to solve the other problem is with the palm top itself if this is the case then you will need to send it off to get the firmware updated you cant do this yourself because you cant get the correct software to do this you might even need to put the device in recovery mode to install the latest firmware so it will need sending off to do this if you contact customer support number for your device then they should tell you the best way of doing this ok
Feb 11, 2008 | Palm m515 Handheld
My calculater has a "comma" instead of a decimal ?
Is this comma between the thousands and the hundreds digits?
Jan 20, 2008 | Palm TX Handheld
Just got Verizon 755p - can the power stay on while charging?
Try StOIC (Stay On In Cradle):
http://mytreo.net/downloads/stoic-stay-on-in-cradle,221.html
It's free and it works - the screen will stay on whenever the Treo is connected to charging power (e.g., in the cradle).
Enjoy!
- IntelelctArsenal
Jan 18, 2008 | Palm Treo 755p Smartphone
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Palm pilot not syncing while in cradle
You can try cleaning the contacts on both the palm and the cradle. For the Palm itself you can try a small pencil eraser.
For the cradle a little isopropyl alcohol on a cotton swab works well.
Do examine the palm socket closely, sometimes the socket is damaged and may recess into the unit so it cannot seat properly
Dec 19, 2007 | Palm m125 Handheld
Static electric discharge - IBM WorkPad c500, c505 (8602-60x / 70x) 2003-08-04
Palm Inc., the manufacturer of the IBM WorkPad, has recently informed IBM that a limited number of IBM WorkPad c500 and c505 models may be unable to use the HotSync function if a static electric discharge (ESD) takes place when the WorkPad is placed in the cradle. Palm Inc. has designed a new cradle for this condition. It has the Palm Inc. logo on it, but also works with these WorkPad models. Palm Inc. has a Web site that provides more information on this issue and also contains the Palm Cradle Exchange Program, which allows owners of eligible models to receive a new cradle. To determine if your WorkPad is eligible and to place an order for a replacement cradle, please visit the Palm Inc. Web site. NOTE: If you are in the Asia Pacific region, please contact the Palm Customer Information Centre in your country for information on how to recieve your replacement cradle. Links to this support information can be found at http://www.palm.com/asia/support/contact/asiapacificsupport.html NOTE: When ordering a replacement cradle from Palm, the entire IBM WorkPad serial number (16 digits) must be entered. The format is 1S8602MMMxxxxxxx (Where MMM is the 3 digit model number and xxxxxxx is the unique serial number).
Sep 14, 2005 | IBM WorkPad c500
Garmin iQue 3600 GPS Receiver Logo
24 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
