Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Physical difference between natural & propane orfice
I have found a good deal on wall mounted gas heaters but not sure if they are natural gas or propane.  I have been told changing them out on these type heaters is dangerous so I do not want to go that route.  I just want to know is there a physical difference that we can tell.
    Problem Solver:
My flame is not burning as high as it did with our other wareheater so iam wondering if it might have the orfice for propane instead of natuaral gas
Posted on Jan 15, 2009
  • 1,420 Answers
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Posted on Oct 16, 2007
How do i convert gas dryer to propane kenmore elite
kenmore has instructions along with the correct orfices you need to burn propane the only difference between gas and propane orfices is the hole size in the center of the orfices and there is very little difference in size propane is smaller hole because the pressure difference between natural gas low pressure proppane higher pressure
Jan 13, 2013 | GE GFDS350GLWW Dryer
Bought a used jandy lite 2 unit. now switching from natural gas to propane. do i need to change all the orifices for propane? if so where can i purchase the orifices near tampa flroida or plant city...
Before you undertake this project, you should know that you will not just need the orfices. You will also need a different gas valve.
gas valve part number is : r0096900 for propane ($300.00+)
orfice part number: L0032900 (set of 2) ($3.00)
As you can see, this gas valve is not cheap. The lite2 is a very reliable heater, but chances are that if its been out of service, yo will also have to replace the thermocouple which will be another $75-$100.
Its very unlikely that anyone at your local pool supply store will have the gas valve in stock. They will definately not have the orfice in stock. Your best bet if you still want to proceed is to purchase these parts off the internet. Just google Jandy pool parts. then goto a few sites, search for the part numbers i gave you, and check for the best price.
Aug 08, 2011 | Jandy Lite2 Lj175n 175,000 Btu Natural...
How do I convert vanguard VMH26TPA wall heater from propane to natural gas?
You would have to get a conversion kit, which usually
is new orfices and a spring that goes into the gas valve. The kit would probably be cheaper than buying a gas valve and the orfices seperately
Feb 10, 2010 | Vanguard International Infra Red - Medium...
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Pool Heater wont light
NO NO NO the heater is design to work on propane or natural gas only
Sep 10, 2009 | Jandy TELEDYNE LAARS GAS VALVE, PROPANE...
30 gallon propane supply tank for residential home, seems appliances are burning too hot, flames are very high what is the cause? Regulator? O2 supply?
could you have gotten a natural gas tank by mistake? it would have larger orfices and allow more gas than you need propane has more B.T.U.s than nat gas and requires a smaller orfice
chack with your gas co.good luck.
Sep 08, 2009 | Rheem RTG-74DVP Direct Vent Liquid Propane...
I'm trying to convert a Jandy 250 BTU propaine pool heater to natural gas and I need the parts
go to the pool store or supply house or call the manufacture if anyone there speaks good english. and tell them what you got and that you need the propane orfices and the propane gas valve and regulator for your pool heater. you'll need to change the orfices, gas valve and regulator.
Aug 06, 2009 | Jandy Heating & Cooling
Can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Feb 28, 2009 | Heating & Cooling
CHANGING AN ORFICE
This unit cannot be converted from gas type to gas type.
Feb 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Trouble with waterheater
DO NOT USE THIS HEATER UNTIL IT HAS BEEN CHECKED OUT BY A PROFESSIONAL!
Most all gas appliances can use propane or natural gas, but they ship from the factory with orifices for one or the other.
Propane is rated at 11 iwg, natural gas at 7 iwg (where iwg=inches water gauge. 27 iwg=1 psig) (it takes a different regulator spring to handle this small difference in pressure.
A propane orifice will be smaller than a natural gas orifice.
The store that you bought the water heater should know what they sold you, and know if they have a kit to convert the regulator and orifices.
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
519 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
