Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Starts right away runs 30-45 seconds then quits.
Engine starts and runs good for 30-45 seconds then quits it will restart and does the same thing time after time
3 Suggested Answers
dennymulford
  • 1055 Answers
SOURCE: Engine cranks, runs for approximately 30 seconds
you nee too take the carb apart and clean it!!!!!!!!!!!!!!
Posted on Apr 01, 2009
  • 15 Answers
SOURCE: engine starts then quits
does it have a fuel filter, or air? If it does make sure they are both clean and free of debris as priming will force fuel up line but will die as soon as its burned out
Posted on May 31, 2010
Cranks but will not start
At very cheap rates you can go for manuals from this store. Just check
Chevrolet Corvette
Jan 26, 2018 | Chevrolet Corvette Cars & Trucks
RUNS AND QUITS
You could try replacing the ignition coil. If it's failed, then it may run ok for a few seconds, but as it heats up it fails. Trying to start again immediately will be too soon for the coil to have cooled down. Leave it a few minutes to cool down and it will run again, but only for a few seconds again.
Hope that helps
Jan 03, 2014 | kawasaki 2011 Teryx 750 FI 4x4 Sport
I have a 93 K3500 with a 454. Truck was running fine, started no problem, ran great. Driving the other day, turn the corner and the engine quit. Cranked the engine, fired up for 2-3 seconds then quit, ...
Before starting the engine, the fuel pump should only run for a few seconds when the key is first turned, to pressurize the fuel system. Even though the pump appears to be running, you may either have not enough or too much pressure for the engine to keep running (fuel pump or pressure regulator). I think it may just be a coincidence the engine quit while turning a corner, but the gas in your tank may have been so low it sloshed away from what is likely a very old pump, starving it and causing it to failure.
Jul 03, 2017 | 1993 Chevrolet C1500
Hi 260 42cc starts good but after using for awhile and shut it off it wont start, it will fire and run a few seconds and quits, does this every time but wont start and run, if i let it sit a few hrs and...
It could be a number of things, bad fuel ( stale) engine over heating and causeing vapour lock, or a bad ignition unit, start with fresh fuel, replace the fuel filter in the tank, try just slackeing the fuel cap and try starting again, this will rule out the fuel tank breather, if still no better replace the ignition unit.
Aug 02, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Rpm guage cuts out and car quits but starts right away all the time
Best thing to do is go to Auto Zone and have the care scanned for any DTC codes. Auto Zone scan free of charge and that way we might get to the problem right away. It could be your cam sensor or crank shaft sensor or both that may have gone bad. There are just to many sensors that can shut down the engine and getting the car scanned will eliminate replacing good parts. Good luck and keep me posted.
Jul 12, 2009 | 1997 Pontiac Grand Prix
Engine quites
Next time the mower quits, immediately unscrew the gas cap and try to restart it. If it runs straight away without a cap, you've found the problem - a clogged gas cap vent.
Clean the vent and you'll be able to run with the gas cap in place.
Good luck !
Marco
Jun 17, 2009 | Garden
Car dies immediately after starting
SOUNDS LIKE IDLE AIR CONTROL VALVE,YOU WILL PROBALBLY NEED A COMPUTER ILDE RELEAN FLASH,IT RESETS VALVE OR IF THAT DOESN'T FIX POSSIBLY AN AIR FLOW METER AND A ECM UPDATE,HOPEFULLY YOU KNOW A TECH DEALER GOOD LUCK
May 17, 2009 | 2005 Infiniti G35
No spark
What about battery and alternator (serpentine belt).
Dec 05, 2008 | 1992 Mazda MX-3
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
228 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
