Question about HP PSC 1510 All-In-One InkJet Printer
Pulled off something while removing jammed paper
I have this peice of "tape" that came off when I was pulling out a jammed piece of paper...Now I cant figure out where it goes or where to get a replacement.
  • 3 more comments
  • nickolem123 May 15, 2009
    Once it jammed it started blinking at me, then I pulled that peice off... I closed the front, and pressed resume... It makes a hard bang noise now when it tries to move the cartridges back across. The tape has some "part information" on the end... It says,
    c9017-80043
    03.05
    087
    THis is how HP lists it... That wouldn't make it non opperational would it? And they show it not orderable?
    C9017-80034
    Absorber - Absorbs excess black ink during the cleaning process
    It's a couple of years old... I doubt the store will do anything.This tape runs all the way across the printer on the inside. clear on either side, but kind of "tinted" in the middel.
  • Frank
    Frank May 11, 2010
    is the tape semi-reg?
  • Frank
    Frank May 11, 2010
    you sure it is from the printer?
    usually there is no tape like thing after the initial shipping tapes are removed.
    tunr on the printer and try to print something, if it works without any problem, then the tape must be some thing you didn't remove before of it s stucked on the paper before it got jamed.
  • 433 Answers
See if the printer works- if not take it back to the store, things should not fall off that easily. Nor taped in such a way that damages your printer. But, if you had the printer a while- Look to the other side of the printer and see if you see another piece like the other piece. Perhaps that will give you a clue as to where it goes. If this didn't help, describe what the piece looks like and where you removed the tape.
Please leave me a rating...
Posted on May 15, 2009
  • John Viguers
    John Viguers May 15, 2009
    Oh, that tape. I am pretty sure you can say, "new printer". That is the instruction strip that controls your printer, which you should not touch (it seems to sensitive). I really thought it was tape that they pack in the printers. Sorry for the miss understanding on my part.
Sharp copier
1) turn machine off or on
2) get a flashlight and look for torn pieces of paper wedged anywhere in the paper path
3) clicking indicates that something is trying to turn but cant because it is stuck
4) dust on a photo sensor
5) broken flag that activated the photo sensor
6) look for turn knobs or release tabs that will let you ease paper out of the machine. Yanking on the sheet with brute force is always a bad idea because the sheet tears and always leaves something behind to get stuck
Aug 23, 2012 | Sharp AR-150 Toner
Paper jam showing red light
did you get a full sheet of paper back out when you removed the jam? If not there is still a small piece of paper in the machine. You will need to get a flashlight and look carefully in the center of the path from where the paper starts (the paper tray) to where it comes out when it is done. if you cannot find any do this: best if you open and close all doors and lids. even the doors behind the printer if there is one. If that does not help try this: Turn off the printer, unplug, count to 10 then plug back in and restart. If the light is still on then light is saying a sensor is seeing a piece of paper or thinks it does. It is possible while you pulled the paper out you pulled a sensor flag out of its holder. By pulling the paper out opposite the paper moves through the machine can cause this. always try and remove a jam with the flow of paper, in other words the same direction the paper travels not backwards. Once fixed can prevent this failure in the future.
Jul 10, 2012 | Xerox Phaser 3117
Hi My Dell Laser 1815 is having a paper jam problem each time it tries to load the paper from the tray.
The paper tray itself is probably missing a small peice. Look towards the front of the tray... there is a guide (about 2" wide) that, if you push down, it springs back and forth. My tray was missing a small peice of flat metal that popped off. The feed roller rests on this piece when the tray is loaded. If the piece is missing, then the roller is to close and the paper cannot make it through into the printer. Still looking for the part number....
Sep 07, 2009 | Dell 1815dn All-In-One Laser Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
My MX310 got a paper jam and when i pulled the paper out a small piece of the corner tore off and is still stuck in the printer. The printer now continues to claim there is a paper jam but i cant visually...
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
Jun 05, 2009 | Canon MX310 Office All-In-One Printer
When going to print paper is pulled in angled and jams thanks
i do not know the model of the printer that you have, but the most common problem is that you have something stuck in the area where the paper is not being pulled in. You might have a small piece of paper jammed in there or some foreign object. It is also possible your sensor is jammed and the paper is hitting it.
Lastly, if you have 2 pickup rollers (depends on the printer that you have), one could be worn out.
thanks adi
May 07, 2009 | Office Equipment & Supplies
Paper Jam Error but no paper is jammed
depnding on which way you removed original jam you could have left a very small peice behind at a sensor arm, inspect very carfully at and before where the jam was
Mar 17, 2009 | Canon D320 imageCLASS Digital Copier
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Clearing a jam I can't get to
I had this problem too. After checking, I found I had not replaced the back peice properly and the paper was getting stuck on an edge instead of rolling as it was supposed to. When I put the back on corectly, the problem stopped
Nov 21, 2007 | HP Photosmart 3210 Printer
I cannot see where the paper jam is
i had the same prob pulled it apart and had to get someone to put it back together ....ha...ha...ha so just get a pro to do it worth the $$$$$$$
Sep 06, 2007 | HP Photosmart C6100 All-In-One Printer
HP PSC 1510 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
