Question about Panasonic KX-TG1033S Cordless Phone
My panasonic kxtg9331t beeps every few minutes or so from the home base (message unit). Does anyone know why? Each of the 3 extension unit handsets are fully charged. Thanks.
  • 89 Answers
Sounds like you may have a "new message" alert indicator. Have you checked that? Go thru the menu on one of the hand sets and find answering machine set up and turn off message alert.
Posted on May 18, 2009
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
CHARGE indicator flashes.
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
I keep getting a system busy, try again later message when I try to place a call. I tried an old phone in the same jack and it works fine.
This is a COMMON problem with this handset. There are only few tricks that you could use to resolve this which are mentioned below :-
1. Unplug the unit for few minutes, say 15 minutes and then turn it ON.
2. De-register and re-register the phone.
3. Pull out the battery. Then hold the locate handset button on the base for 4 seconds.The base would beep for around 30 seconds and could resolve the problem.
If the problem persists, you need to send the unit for repair.To be honest, i would afraid to send the unit for repair as the repair cost would be high as compared to cost of the set.Buying a new set would be a much better and wise option.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 | Panasonic KX-TG1033S Cordless Phone
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
No link to base
This may help. It's from the Panasonic help page:
You may try to:
Disconnect AC power adapter from the back/bottom of base unit, then connect it again properly.
spacer.gif OR, to resolve this issue, you have to re-register the handset.
  • To do this on a non-expandable cordless phone:
    Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
    Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
    When registration is complete, a beep sounds from the handset.
    Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
    If this fails to help:
    Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
  • To do this on a expandable cordless phone system:
    Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
    Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
    Remove the AC Adapter from the base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Jun 24, 2009 | Panasonic KXTG5632BP Twin Cordless Phone
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
How to use intercom between two handsets
For models with 2 or more
handsets included
Making an intercom call
1 Press {INTERCOM}
2 To page the base unit, press {0}.
To page another handset, enter its
extension number ({1} – {4}).
The destination unit beeps for up to 1
minute. Someone else can answer the other unit and talk to you.
3 To end the intercom call, press {OFF}.
Aug 18, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG1033S Cordless Phone Logo
514 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
