Question about Cakewalk Computers & Internet
I have sonar 6 le[cakewalk.been recoding for moths so i know what i'm doing..today it won't record..it playes back files i have on there but will not record a thing..i see the dial moving on playback but the record metors don't move at all.. i'm not a goof on the computer but i'm not a geek squad guy either if you get my drift..lol ps.i hit record on 1 channel that i use..i make it stero..hit the bottom where it says all..its white..but record levels do not move..thank you
    Scholar:
  • 155 Answers
I have tried using different program for recording. It does work for some time but time came when I have also problem met with it. So I uninstall it after clearing all folders etc in program files and in Control Panel, I tried to re install it. PRESTO! it worked with that fine.
Try unistalling if you have the isntaller with you and the Key product.
TNKS
Posted on Jun 21, 2009
Goodmorning, I'll try to explain the problem: when I listen to the files (MIDI and MP3) directly with Cakewalk sd-50 using the USB Key the playback is correct. When I listen to the files playing them...
You have to make sure that the clockspeed of the program that you use to play the files back with matches the clockspeed of the program that created them. I might be wrong about that. Here is a good resource:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will have to join to access but its free and the Killer Home Recording setting up is also free from the site and is full of good info.
Dec 13, 2010 | Cakewalk Roland SD-50 Mobile Sound Canvas
I have sonar 6 le on windows 7. I am using a cakewalk roland interface. something is wrong with the sound, it makes noise during playback. I also hooked a mxl v67 mic and it is sounding pretty wired dont...
I suggest you make a backup of your music files, uninstall cakewalk and reboot your computer to make certain there are no files left in the RAM then re-nstall it. That will ensure that your installation is a clean one.
If that has no effect, remove the sound drivers from your system and re-install the latest versions from either Windows or the manufacturer's web site.
That should fix your problem.
Hope this helps.
Oct 28, 2010 | Computers & Internet
Choppy recording
This could be to do with the format your using to playback.
Hope this helps!
Feb 05, 2010 | Cakewalk Sonar 5 Producer Edition Full...
If i play something i hear only 3 seconds music and than it stops. What can i do?
try downloading AC3 filter
go here:
http://ac3filter.googlecode.com/files/ac3filter_1_63b.exe
download and install that and then tell me what happens?
Dec 11, 2009 | Cakewalk SONAR Home Studio 6 XL Recording...
Stuttering during audio playback in Sonar
The stuttering is caused by excessive CPU usage, in other words: you have too little CPU power to play the file with the inserted synth smoothly. You could try inserting a different synth or play with the rendering-options of the synth (like disabling aliasing, etc.) or increase the audio buffer size (under audio options ?), but the only longterm solution is upgrading to a much faster computer.
Even when you find some tweak which lets you play the file (just) smoothly, adding another effect or synth is likely to cause it to stutter again, since your computer doesn't meet the official (!) minimal requirements for running Cakewalk Sonar 6, which is at least a Pentium 4 1.3GHz computer (and you have a 1.0GHz computer).
I would recommend upgrading your computer to something which at least meets the "recommend requirements" of Cakewalk Sonar 6, which is a Pentium 4 2.8GHz or newer (like any Intel Core 2 system), when you're serious about composing music.
Aug 12, 2009 | Cakewalk SONAR Power Studio 660 Full...
Timing after recording. and midi composing
May I suggest you try to adjust your audio settings inside Sonar. Also it is a good idea to always keep your C drive well defragmented. I once had this problem using Sonar LE and the only way I got rid of it was after formatting my C drive and reinstalling the drivers and Sonar again. After that the problem came back and then I upgraded from the SB Live to Audigy SE.
Make sure you also have lots of free space on your C drive and have a decnt amount of ram.
May 11, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Me and some buddies record with sonar home studio 6 and i bought a new pc custom built for recording well our computers on tha same day and time started having problems with sonar popping and glitching...
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Mar 06, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Computers & Internet Logo
432 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
