Question about Gateway nv Computers & Internet
NV55C battery won't charge
Getting blinking blue and amber lights and battery won't charge.
    New Friend:
    Problem Solver:
  • 6 Answers
Battery needs to b replaced
Posted on Oct 13, 2014
SOURCE:
cheap to fix
  • 404 Answers
SOURCE: toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Posted on Mar 03, 2009
leecom72
  • 4806 Answers
SOURCE: amber light constantly flashes when trying to charge
Hi there.
The battery could be faulty, power off the laptop, take out the AC power and the battery wait 2 minutes and put the battery back in, turn the laptop an and look at the indicator LED to see if its changed, if it has plug in AC power and see if its the same.
Good luck and thanks for choosing FixYa!!
Posted on Jun 01, 2009
benwabnick
  • 2404 Answers
SOURCE: 1721 Inspiron shows flashing amber, three times, then blue.
The cells in the battery are starting to go bad which is why the light is blinking the way it is.
Once you get a new battery put in there the light will stay blue instead of flashing amber.
Posted on Jul 04, 2009
  • 73 Answers
SOURCE: Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Posted on Sep 23, 2009
mbostermeyer
  • 58 Answers
SOURCE: The blue and amber light flashing on the battery indicator
You should talk to a Dell support specialist. The blinks are actually a code that tells you exactly what is wrong with it.
Posted on Oct 24, 2009
Camera won't charge red light is on but the green light doesn't come on . What is my problem ? Could it be the battery
hi Kenny.
With most cameras, an amber, yellow, or red light indicates a battery that's currently charging. A blue or green light usually means the battery is charged. A blinking light sometimes indicates a charging error; other times, it indicates a battery that is still charging.or faulty battery.
have you tried,take the battery out and then put it back in?.
make sure the battery is seated.and its making a good contact.
Dec 01, 2017 | Green Cameras
Blinking battery light
If it has not been charged for a long time, it will probably take a while to start charging.
Aug 28, 2014 | Dell My XPS M2010 Notebook
Lenovo z570 not powering on
Measure the voltage at the AC Adapter plug, and see if it is within 5-10% of the rated voltage. If the voltage is not correct, then the battery will most likely not be charging, and the system will drain the battery and die in the middle of what it was doing...booting in your case.
You can tell how much voltage is remaining in your battery and if it is charging by checking the blinking of the battery status light.
Download the Hardware Maintenance Manual here:
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Z370&Z470&Z570/Lenovo%20Z370Z470Z570%20Hardware%20Maintenance%20Manual%20V1.0.pdf
and go to page 30 and look at item 7 under battery status for blinking light meaning.
1. Blinking amber: (500ms off/1s on)
The remaining power of the battery is less than 5% of
its capacity.
2. Blinking amber: (100ms off/3.2s on)
The battery is being charged with the remaining
power between 5% and 20% of its capacity.
3. Amber: The computer is operating on battery power with the
remaining power between 5% and 20% of its
capacity
With the AC Adapter plugged in, and giving the correct voltage, If you are getting 1. Blinking Amber (light on for 1 sec, off for 1/2 second), then the battery is not being charged. Could be AC Adapter, Battery or Battery Circuit on motherboard. If the light is solid on 3. Amber, then the battery is not charging, and is draining.
Also make sure the power socket on the laptop is not loose or damaged. If it is, then it will need to be replaced.
I hope this gets you in the right direction.
Apr 25, 2014 | Lenovo IdeaPad Z570 Notebook
Wi-max light deep blue Power and charging and battery light blue-white HDD light blinking
Make sure your dvd rom does not contain a disk.
Your system checks your dvd rom drive first for a bootable disk.
A blinking HDD light is normal during boot up.
Feb 06, 2013 | Toshiba Satellite Computers & Internet
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
How will I know when my wireless headphone is charged up
usually these kind of devices luminate in different colors. but almost generally when charging or the battery is down it usually has an amber or red light and blue wen charged. alternatively sum blink when charging and the light is steady when fully charged
Aug 08, 2010 | Computers & Internet
What does blinking orange light on the phone mean?
Solid amber light when the battery is being charged.
Flashing amber light when the remaining battery level reaches below 10% htc has had some problems with batteries,when charging, if you are getting the flashing amber light feel the back of the phone. if it is feeling hot you may have a bad battery. hope this helps.
Jan 23, 2010 | HTC Touch Cruise Smartphone
Jul 04, 2009 | Dell Latitude D600 Notebook
Toshiba 1410-S173 battery charging light blinks amber
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Computers & Internet Logo
150 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
