Question about Sub-Zero Bottom Freezer Refrigerator
The fan keeps running by the motor
The refrigerator and the freezer are operating fine but the fan has been running for about 12 hours. Is this normal
  • shaun greyvensteyn May 11, 2010
    the fan must only run when the motor runs
  • 159 Answers
The fan must only run when the motor are running
Posted on May 16, 2009
Hi, I have a GE side by side GSS23LSTA refrigerator The last few days it has been running constantly. The refrigerator side temperature is fine at 35 degrees, but the freezer temp is staying at around 12...
Hi Mark and welcome to FixYa, I am Kelly
Touch the front of the unit where the doors close and feel if it is very very warm to the touch. If it is very warm to the touch... here are the prime suspects:
1. condenser coils covered in lint
2. condenser fan not running or running slow.
An easy way to determine if there is a condenser fan or coil fan problem is to simply direct a floor fan at the base if the refrigerator. If it cools down substantially in an hour.... there is a problem with the coils being clogged or the condenser fan not running. If that makes no difference... before opening the back of the unit... inspect the back wall of the freezer compartment for any signs of ice build up. If you see ice-build up.... unplug the unit.. remove freezer contents and direct that fan into the freezer compartment for just over 2 hours. Then return the unit to normal service.... If the temps come down to normal... for 2 - 3 days then start creeping up again... you have an automatic defrosting problem.
Forgot to mention... make sure the evaporator fan is running at full speed.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
FixYa: We understand that your problem is: I have a 2007 side by side Kitchen Aid Refrigerator. It seem that the motor runs non stop. The coils are clean. The house temperatures are constant and the...
Hi there
Maybe nothing
1. The fan in the freezer compartment runs full time, this could be the motor noise you hear
If the temperatures are OK then it can not be the compressor that is running all the time or the freezer would go really low in temperature.
You need to pull out the unit and confirm that it is the compressor that is in fact running all the time, they normally run around 12 to 16 hours each day
2. The other unlikely possibility is if the compressor is running full time then there may be a fault with the compressor, busted suction valve or the system could be low on gas.
Regards
Gordon
Apr 21, 2011 | KitchenAid Refrigerators
I just had a professional mover move a Kenmore 20 19.5 cubic foot side by side refrigerator out of my sister's condo to my home. It was in the upright position at all times and moved gently. It was...
is the fan motor running in the freezer..?if its not locate it an turn fan blade to see if it spins freely retry the frig to see if it works ..is the coil in the freezer frozen up..?if so defrost it completly ..then recheck operation ..let me know ..good luck ..PS you may need to remove covers to get to motor //joe//
Aug 27, 2010 | Kenmore 57029 Side by Side Refrigerator
Model 106.9630280 The freezer is working but
you probably have a bad air circulation fan or a restriction in the ductwork between the freezer and the refrigerator that the circulation fan supplies the cold air from the freezer to the refrigerator compartment. you should be able to hear the circulation fan motor running when the unit is in normal operation mode. the only time the fan will not be running is when the unit is in defrost mode which occurs once every six to eight hours depending on the defrost timer in your unit.
Mar 14, 2010 | Refrigerators
Not blowing cold air
unplugged the unit, kept the doors closed about 10 to 12 hours plugged back in and in about 2 hours started blowing cold air into freezer another 4 hours was blowing cold air into refrigerator and continuily got back to the themostat settings,about 1 day. no food was lost because the doors were closed still keeping it cold. i think the fan in the freezer was frozen with ice,but could access it, not the main fan in the back the unit by the compressor,that was running fine. so basically i defrosted the freezer fan by unplugging it. this is the 2nd time in 4 years ive done this, well it beats spending 1000-1500 dollars to replace it TRY IT I HOPE IT WORKS FOR YOU BEFORE YOU CALL FOR SERVICE,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Kenmore 77563 Installed last week and freezer defrosted all the food
The refrigerator & freezer operate using the same system. One system. Your still covered by the warranty and I would suggest calling the installers or store from which it was purchased. The problem may be a faulty fan switch .
Apr 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My whirlpool Refrigerator motor keeps running
Keep an eye on the running time and temparture of the refrigerator. It will need time to return to normal cooling temps since the defrost and hot temps inside will take maybe a few more hours to reach normal. If not, get back with me and I will go through a step by step process on eliminations,  If so I will need age of fridge, Make and Models Numbers, Thanks Sea Breeze
Oct 27, 2007 | Refrigerators
Sub-Zero Bottom Freezer Refrigerator Logo
408 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
