Question about McCulloch Garden
Need owner's manual for Mac Cat chain saw, Mod. 6000-38-16, Ser.21-022331 (1997). Other info: 2.3 ci (38 cc) Anti Vibration.
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
slohry
  • 87 Answers
SOURCE: Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 09, 2009
SOURCE: I would like an owners manual for a mcculloch
A parts book can be found at the following URL.
http://mcculloch.motoruf.de/spell/get_file.php?filepath=/Mipl/pspm310.pdf
That's all i could find?
Posted on Jul 23, 2010
puertobori
  • 7733 Answers
SOURCE: I am in need of
Try this
Parts -> Link
Manuals-> Link
Post back!
Posted on Oct 03, 2010
Why pole saw wont saw?
There could be a couple of reasons why your saw won't cut.
The first thing I would check is to make sure you have your chain facing the right way.
The chisel edges should be facing forward, or in the direction the saw chain is rotating.
If this is not the problem, then I suspect the chain itself is dull.
Jul 08, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
16 inch poulan chainsaw got hot and started to smoke and now the recoil no longer works. I took the cover off and there is two springs that seem sprung. should I toss it and forget it or this something I...
how old is the polan 16 inch is it a solid body saw or does it have anti vibration handles, so your hands dont go numb after cutting for 15 minutes.reason i asked is: you can buy a brand new reconditioned homelite with anti vibration handle for 85.00&shiping.
at the very least,your polan needs the recoil starter fixed
and that does not address why the poulan got hot & started to smoke.
For the problems you described , at least $100.00 labor plus parts to fix at a chain saw shop
It might barely be worth it if you were a do it yourselfer and wanted to try to fix it.
if you dont want to be a diy chain saw mechanic, sell your polan for parts for $20.00 on ebay and buy a new homelite
16 inch 38 cc with anti vibration handle ,so you can cut for 6 hours straight, if need be. You get a reconditioned saw that is ready to go and a 90 day warranty. or buy the saw brand new for $110.00 and free shipping@ amazon.com
Oct 07, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I can start my Poulan 2000 16" chain saw but it
If the saw is brand new, take it into a service dealer for a carb adjustment (covered under the warranty). This sounds like it is your issue and unfortunately, you cannot correct it yourself because it requires a special tool.
As for you manual, it is located at the link below http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137248.pdf
Jun 25, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How do i take the oil tank off a 41 cc husky chain saw
I guess we are talking about the Husqvarna 41/141, start by removing the guide bar and chain, remove top cover, disconnect and remove the throttle wire, remove the fuel hose from the carb, use a 4mm allen key and remove the front anti vibration rubber screw ( drive side, bottom front r/h, holding the alloy chain catcher ) now remove the top anti vibration rubber screw with a cross head screw driver ( top l/h holding an orange plate ) now remove the four screws securing the starter cover, two screws are into the plastic crankcase, and two are into the anti vibration rubbers, the fuel tank should now pull out from the bottom of the saw withe top handle still connected, make sure the fuel hose feeds out of the crankcase as you pull the tank away.
Feb 10, 2011 | Garden
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
May 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Chain Saw (Model 2775) Handle keeps coming loose.
If it keeps coming loose, you could try some thread-locking solution on the screw to keep it in place. The spring is there as an anti-vibration measure (well a vibration reducer) so the saw is more comfortable to use and so it doesn't cause excessive fatigue through constant, high vibration transmitted through to the handle. You could of course remove the spring if you wanted to but the saw is likely to be pretty uncomfortable to use. Without seeing the saw in person however, there must be some reason the screw keeps loosening... See if you can find that issue and replace the affected part, or try some threadlocker in the meantime.
Mar 16, 2009 | Poulan Pro Chain Saw 46cc 20"
Need owners maual for mcculloch power mac 6 chain saw
Jan 27, 2009 | Garden
Garden Logo
858 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
