Question about HP OfficeJet 9120 All-In-One InkJet Printer
HP 9120 Constantly aligning printheads
My HP 9210 is constantly aligning the printheads. Have to turn it off to make it stop. After I replaced the black ink cartridge this happened. Have never replaced the printheads. The color ink cartridges are expired, but I backdated the machine so they would be okay.
  • Donna Lam
    Donna Lam May 15, 2009
    We've had the printer for about 4 years now but it is now and has always been rarely used because it is so incredibly slow. We were a victim of false advertising, said it would print and copy up to 22 pages per mintue color and 25 ppm b&w--in what universe that would happen, I don't know.
    So, I know you said to replace all the printheads and the expired ink. That's $300+ to do that. Do you think it would be wiser to first replace the expired ink cartridges to see if that stops the printheads from constantly aligning? Or does all of it need to happen to stop the constant aligning?
    Donna
    Guru:
  • 832 Answers
Hi thanks for using fixya!
I recommend that you should replace the printheads to anew one. And you have replace the color ink cartridges as well. If you have used an exprired cartridges, it will result an error to your printhead. Always make sure that you always change the ink cartridges whenever it is required and if you are frequently using it heavily. Backdating the machine is helpful, however it will be more efficiently if you replace the printheads. By the way, how many years now your are using your HP printer? Did you had a chance to send it to any HP Service Center for maintenance as well? I recommend to my clients if they are heavily using or not the machine, it should be always be maintained every 6 months.
If you need further assistance, let me know.
Posted on May 15, 2009
  • Dennis Jambalos
    Dennis Jambalos May 15, 2009
    Yes, definitely, as I mentioned earlier, you shoud change your ink cartridges whenever it is required. The expired inks won't help at all. The printheads keep on aligning due to the error, as you know the printheads has its sensor, to detect whether you need to change inks or if you are using fake ink cartrdiges. If the cost of changing the printhead and the ink cartridges is not practical but instead of buying a new model of printer that suits your work.
Je pumpmst 0pmd1 120 /2 hp 50/60 hz. single phase Had o replace piggyback plug now pump runs constantly .ISs this normal if not how do i fix the problem?
The piggy back plug connected to the switch that turned the pump on and off. It sounds like the pump now cnnectes directly to the line without the switch in series with it.
Jan 24, 2014 | Plumbing
Tip
The green light is blinking constantly and the printer won't print
Often happens HP cartridges to overheat.In that case the printer not recognize it and the green lamp blinking constantly.In most case only one of both cartridges defective and need to be replaced.But how to know which one?
Here's how: Open cover, put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
on Oct 21, 2009 | HP DeskJet 3745 Printer
Replace print heads. How?
REPLACING HP PRINTER, PRINTHEADS
Follow these steps to replace the printheads in your printer.
  1. Press the Power button (c00636182.gif ) to turn on the printer.
  2. Open the top cover.
  3. Press and hold the Resume button (c01219285.bmp ) until the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left side of the printer. If the carriage does not move to the left automatically, turn the printer off and back on and then try holding down the Resume button (c01219285.bmp ) again. The printhead can be damaged if the carriage is not all the way to the left for installation.
  4. Lift the printhead latch. Figure 3: Lifting the printhead latchc01290070.gif
  5. Lift the handle of a printhead and use it to pull the printhead out of its slot. Figure 4: Removing the old printheadc01295543.gif
  6. Shake the new printhead at least six times while the printhead is still in its packaging. Figure 5: Shaking the new printheadc01134519.gif
  7. Remove the new printhead from its package, and then remove its orange protective caps. Figure 6: Removing the protective capsc01134520.gif CAUTION: Do not shake the printheads after removing the orange protective caps.
  8. Insert the printhead into its color-coded slot (the label on the printhead must match the label on the printhead latch). Press down firmly on the printhead until it snaps into place. Figure 7: Inserting the new printheadc01290071.gif
  9. Pull the printhead latch all the way forward, and then press down until the latch engages. Figure 8: Closing the printhead latchc01290072.gif
  10. Close the cover. Figure 9: Closing the coverc01290073.gif
  11. The printer should align the printheads automatically in a few minutes, printing an alignment page. If it does not, go to the next section to align manually.
Align the printheadsIf you installed the HP software, use the instructions in the left column below. If you installed a Plug and Play driver or other driver, use the instructions in the right column.
Mar 05, 2010 | HP Office Equipment & Supplies
HP 2175 Printer won't align new ink cartridges.
press 'setup' and 'options' buttons at same time to overide
Mar 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
Our printerhead keeps going bad
You should call HP and tell them you need a new printhead. There is a feature in your priter software or in the menu to clean printhead. Try a deep clean.
Jan 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Fan is running constantly
in the 9120 series the fan is allways working, but as 2 speeds. the higher goes of when the load goes around 80% or the temperature inside is higher. just make sure the the fans are clean, and check the ups temperature.
but is normal.
good luck
Jun 09, 2008 | Powerware 9120 UPS System
HP Officejet 9120 all in one
i want free download hp officejet 9120 printer drivers what a i do??
May 05, 2008 | HP OfficeJet 9120 All-In-One InkJet...
OfficeJet 9130 all-in one
I updated the HP 9130 firmware and encountered the same problem. I turned off the printer, removed all the printheads and the cartridges, closed the printer cover and then turned on the printer again. After seeing an error message on the printer screen concerning the missing printheads, I opened the printer cover, replaced all of the missing printheads and the missing cartridges and then closed the cover. The printer then aligned printheads once as is expected after replacing the printhead and cartridges. Thereafter, it worked normally. I do not know why this procedure worked and if it will work in every case, but for now, it seems to have worked for me.
Apr 10, 2008 | HP OfficeJet 9130 All-In-One Thermal...
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
Dec 03, 2007 | HP Officejet 9110 All-In-One InkJet...
HP OfficeJet 9120 All-In-One InkJet Printer Logo
266 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
