Question about Coleman Mach 15 Air Conditioner
Not putting out cold air
The compressor sounds like it is running but after an hour no temp.change from intake. I placed thermo. at nearest duct. inside the vent. It is a rv roof unit. It sat for two years before being run. I,ve looked everything over and all looks ok. Next step measure line voltage? how? Then compressure amp? w/ outside ambient air temp. To calculate RLA? Any guidance would be helpful. Thanks
  • 148 Answers
Check freon level
Posted on May 15, 2009
Montana ac problem
some external sensor has taken a knock etc
sounds like its not getting whats going on outside
or the evaporator has an issue with its drains
perhaps something in the air intakes
Dec 23, 2014 | 2001 Pontiac Montana
Refrigerator runs and will not shut off, keeps getting colder and colder no matter what setting I put it on?
I have the same problem. My 7 yrs old Beverage Air model MT27 got very cold even with temperature control set to almost off position. It froze all the water and pops in it. Somebody have the solution?
Oct 12, 2011 | Beverage-Air MT27 Beverage Cooler...
2002 Ford Escape V6 4WD A/C works but while driving long distance >100 miles and while driving at speed (70 MPH) the HVAC [set to A/C or Max with the temp all the way cold], changes on its own and...
Sounds like you are losing vacuum to the HVAC system control or the mode control switch is defective. When you have this problem you will most likely find the air is coming out the defrost vents as that is the default flow when vacuum is lost to the system.
Mar 15, 2017 | 2002 Ford Escape
Air conditioner cycles cold then warm
sounds like you have a slipping AC compressor drive belt. at low engine rpm it is less noticeable... check all belts also check for any siezed up idler pulleys...
Aug 11, 2009 | 2002 Jeep Liberty
A/c stops blowing cool air after 90 minutes to 2 hours driving
sounds like it has a slow leak in it i would put dye in it and drive with it on for about 3 days and take a light see if u see dye comeing out anywhere
Jul 19, 2009 | 2004 Dodge Intrepid
In car airconditioning system there is a filter with glass window where you can see if the gas is bubbling if so then your system have no sufficient freon gas.
Jun 01, 2009 | Coleman Mach 15 Air Conditioner
Fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Mar 14, 2009 | Samsung Refrigerators
Will not heat below 40
2nd stage heat should kick in on auto defrost ,sounds like bad sequencer or relay
Jan 27, 2009 | Intertherm P3RA-036K Air Conditioner
Air Conditioning
Try changing the lower temp sensor in the air duct on the drivers side. I bought one and never replaced it. before the part arrived I took the lower sensor out and taped it up and put it back under the dash... not in the air duct housing were it belongs. believe it or not it works so well I did not even see a need to change the thing.
Jun 22, 2008 | 2001 Cadillac DeVille
Coleman Mach 15 Air Conditioner Logo
234 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
