Question about Whirlpool Duet GHW9150P Front Load Washer
F24 the machine will start and then just stop and the F24 message will come on. the engineer came twice to fix it and the problem remains what can i do?
  • 1 more comment
  • parnel Nov 30, 2007
    I also have an F-24 error code on my Whirlpool Duet Sport HT washer, but I think it is better than the F-01 error code I had before when I had to get the machine replaced, because at least now my clothes are not locked inside. I really hate this washing machine!
  • ddkraft Sep 05, 2008
    I usually get the "f-24" error code because of too much suds, or something similar but this time I had the washer on "rinse & spin" & I got the F-24 error code. //HISTORY: my washers puts water all over the detergent,bleach,softner holders (thereby putting everything in the first wash) and I have learned that if I want softeners in my clothes I must run a second cycle just for that - so all my clothes get washed twice// I have learned that the error codes that I see can be cleared by turning the washer off (or pressing cancel)(one or two times) and the start wash cycle again.I have two whirlpool washers (duet) & two gas dryers (duets also) but this is the first time that I have had the F-24 error code during my second rinsing cycle & I just wonder if this is a precurser to the washer breaking down on me. if you can figure it out I would love to know - Please be advised that (after two years) I consider these whirlpool "duets" a bad purchase and am waiting for them to break so I can have the pleasure of throwing them out in my swale area for the garbage truck to pick up. But I would still like to know the specifics of the error code "F"-24.
  • shells626 Oct 02, 2008
    Upon washing my clothes as normal, the F-24 error appeared on the washer. So I've turned to the internet since I purchased this product and have misplaced the owner's manual. I am not sure what F-24 means however after reading other peoples comments it sounds like F-24 means too many suds in the cycle. Is this correct? Need I do anything more then run the cycle once more without adding any additional detergent? Thanks
Where can I find the tech manual? I need to the same thing (thermistor error-F05)
Posted on Jan 08, 2012
My washer had the same F-24 error code. The tech manual inside the bottom cover said that it had to do with the temperature sensor. I removed the back and the top cover, and found the CCU (the brains of the washer). Following the directions in the tech manual I ohmed out the temp sensor and found that it was OK according to the manual (approx. 12k-ohm). I followed the wires for the temp sensor starting at the CCU (using the schematic in the tech manual) to the opposite end and found that the connector was loose. I re-inserted the connector and the washer started to work fine - no more F-24 error code.
Posted on Jul 13, 2008
I have a Duet front loader... Received F- 24 Error... Reset All... Noticed water (probably drain error?) still at the bottom of tub... Set to rinse\spin ... Letting it cycle now... Few weeks back found debris where some drain holes were... Hopefully none of that made it internally.. May take the lower panel off for reference tonight... Thanks All..
Posted on Mar 11, 2008
    Sergeant:
    Champion:
  • 262 Answers
Take the front lower cover off and there is a tech sheet in there look at it and it will tell ya what the code is for and how to correct it I cant remember this code off the top of my head and all the brands have different codes.I have about 5 three ring binders of tech sheets in my van if you cant find it i will look it up for you once you find this sheet clear the code and run it through diag.mode the sheet will tell you how to put in in self or automatic try auto. good luck
Posted on Dec 22, 2007
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
F24
does the drum just move back and forwards or does it turn complete turn if it dont do complete turn it might be that the belt is slipping and needs replacing this is cheap and easy to do post back if you need more help but i had a machine with same prob but mine was different make and model but after replacing the belt it solved prob and is still working to this day sorry if this is not much help .........................................................
Nov 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader
I've had this same problem and had a service man come in. The reason for the colde is an over-gunked up machine due to the directions for amount of soap to use on he bottles being incorrect.
Run the washer empty several timres with just vinegar in place of the soap and then repeat with bleach. I've been told this will take care of the problem, but it may take many cycles before the codes will stop appearing.
Also, from then on, only use 3 tablespoons, yes 3 tablespoons or 1 ounce of detergent per wash. The 1/4 cup that most he detergent bottles tell us to use is way too much.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
F24
heater or drain fault Regards Engineer
May 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,014 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
