Question about HP Compaq ProLiant DL380 G4 Server
Cpu fan failed
Is the cpu fan on a hp dl360g4p hot swappable?
  • HP Master
  • 3,866 Answers
I have done it before on a prliant while the server was hot.. Live but will careful and ease do not go in there heavy handed.. but it can be done
Rulds2008
Posted on May 15, 2009
My laptop gets very hot on one side when plugged in
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 07, 2013 | HP Pavilion Computers & Internet
Overheat and shutdown hp mini laptop
Mar 06, 2013 | HP Mini 1000 Netbook
Fan failure in bay 2
Open and replace it. They are hot swappable.
Jan 19, 2013 | HP Compaq ProLiant ML570 G4 Server
Hp proliant ml350 gen5 keeps shutting down unexpectedly.
Open the top . Turn on. Populate any empty fan slots, and replace any with amber / red indicator lights. You can also try reseating. Fans are hot swappable.
You should have been using Insight Manager. Login locally and go to http://host:2301 you need the SIM administrator password. It will tell exactly what is wrong.
Oct 06, 2012 | HEWLETT-PACKARD HP ProLiant ML350 G5 Base...
Cpu hot
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 15, 2012 | HP Compaq Business nx6125 Notebook
Mycompaq presario c769 us get hot so much
Apr 01, 2012 | HP Compaq Presario C769US Notebook
What might be the cause when machine gets hot when shut down
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 24, 2012 | HP G62144DX Laptop
Continuous beep and the systems is not coming up {boot}
Hardware problem:
* dead RAM
* dead video-card
* RAM not fully "seated" in its slot(s)
* video-card not fully "seated"
* dead fan on top of the CPU/heatsink.
* failing power-supply.
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
My dv9000 locks up after it gets hot. What can I do?
A laptop locks up or shuts down when it get very hot. The CPU shuts down (thermal overload) when it overheats and will not boot up until it has cooled down. If this problem is not fixed, eventually the CPU will fail.
This problem could be caused be a faulty CPU fan and/or the CPU and heat sink assemble is clogged with dust.
Check the CPU fan to see if the fan blade spins freely (it may have a seized bearing), if not replace the fan. If the fan and heatsink is clogged with dust, clean and remove the dust.
If additional cooling is required and there are ventilation grills on the bottom of the laptop, then purchase a laptop cooling pad. Place the laptop on the cooling pad, these pads have fans that direct air into the grills at the bottom of the laptop.
Jul 21, 2010 | HP Pavilion dv9000z Notebook
How to install hdd in pro liant 150 G6 as i got it without hdd and i can't find out how to install it in the blank ? thanks
HP Proliant 150 G6 has a hot-swappable harddisk cage in the front. Open the front cover and you will be able to slot in the hot-swappable hard drive.
Jun 13, 2010 | HP ProLiant ML150 G2 Server
HP Compaq ProLiant DL380 G4 Server Logo
244 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
