Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Gas leaking in a stream from other end of primer line
On the primer bulb line on inside of filter was leaking gas i took flter off the gas was steadily streaming from end of the line from the primer bulb till it emptied i tried pushing the primer bulb but it only came out faster i dont even have to push it 3X its just pours out by itself till tank is empty how can i fix it
  • 13 Answers
Something is causing the float in the carb to stick in a downward position. This float tells the carb when to cut off the flow, and stuck down it keeps the channel open for gas to flow through. Empty the gas and remove and thoroughly clean out the carb, making sure you hit the float bowl very well. Worst case the float could be bad. If cleaning it thoroughly doesn't get it, consider a carb rebuild kit from the engine manufacturer or replacing the carb.
Posted on May 16, 2009
Why does gas bulb collape and does not fill up and which gas line goes to which nipple on carbuerator?
The line with the filter should go to the carb, then from carb to suck side of primer and return to tank from the blow side of primer.
not sure if this will apply to your situation but is just what ive gleaned from experience
Dec 18, 2014 | Garden
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 04, 2010 | Craftsman Convertible 25cc. Gas Line...
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Need diagram for fuel line in tank fuel filter
The small diameter fuel line that has the fuel filter in the tank on it goes directly to the carburetor (with the built-in primer or externally mounted primer). IF the carb has the external primer, the small line goes to the nipple on the carburetor opposite the end with the hole in the cover. If it has the built-in primer on it, it goes to the carb body on the nipple furthest from the bulb. The large diameter line is the fuel return line and if the carb has the bulb on it, this line connects on the nipple closest to primer bulb.. With the externally mounted primer, this line connects on the longest nipple coming out of the primer and goes to the fuel tank (not the filter though). There is a nylon connector inside the tank that holds this larger line in place. The shorter nipple on primer bulb has a smaller diameter fuel line connected to it and connects to the nipple on the carb closest to the end with the hole in the cover. Built in primer has 2 fuel lines...externally mounted has 3.
Jul 31, 2010 | Craftsman 25cc Gas Line Trimmer
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Jul 06, 2009 | Garden
32 cc Craftsman (Poulan) gas line replacement
Yes, you are right. The larger line goes to the primer bulb and only goes into the tank about an inch. The coupling just keeps the line from pulling out of the tank. The smaller line goes to the carb. This line must rest comfortably on the bottom of the tank with the filter attached to the end.
Jim
Jun 07, 2009 | Craftsman 25cc Gas Line Trimmer
Replacing a fuel line for a Poulan 2175 type 2 chainsaw
Take top cover off(3 screws). Take off the 2 nuts holding the carb on. Pull carb part way out to access the hoses. Remove the 3 old hoses after making a diagram of where they connect. Buy new hoses. Cut one end of the small hose on a bevel, pierce both sides 1/8 th inch from the end with a needle. Thread a thin wire through both holes. Thread both wire ends into the gas tank. Use a hemostat or long needle nose plyers to pull the wires and then hose down into the tank. Attach the weighted fuel filter. The other end of this smaller diameter fuel line goes on the upper nipple on the carb. Take the side cover off (4 screws) to access the primer bulb. Take 2 screws out to remove the bulb which has 2 nipples. The longer nipple connects to the larger diameter hose which goes to the fuel tank. The larger diameter tube has a coupler on the end which is inside the gas tank. It took me an hour to change all 3 hoses.
Bob
Jan 31, 2009 | Garden
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
514 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
