Question about RCA Universal Remote Control
Smart antenna I live in a small town im surronded by trees i live in apartments.I get very bad signal even with an antenna on my converter box .I only get like 10 channels when i could get even more channels with just an antenna and no converter box.Whats the best antenna for the box. I have a phillips antenna
    President:
  • 2,992 Answers
Just because you got lots more channels with the old analog broadcasts, it doesn't mean you can get that many with digital. With analog, you could get a watchable picture from a distant station even if it was weak. It just meant the picture might be a little snowy or fuzzy. It's a lot different with digital.
Digital reception is pretty much "all or nothing". That means either you get the channel or you get a "no signal" message. If the signal from the antenna is too weak, unlike the analog fuzzy picture there is nothing at all.
10 channels isn't a bad number, by the way. A lot of people are finding they get far fewer than that, even no channels at all. It all depends on your distance and direction from the station. If you go to www.antennaweb.org and click on "choose an antenna", they can help you determine what stations are on the air around your area, how far away they are, and what type of antenna would be required.
The "best" antenna is the one that gets the strongest signal from the most stations. For your specific location, this might be as simple as amplified rabbit-ears. Or it might mean a large rooftop antenna that you can turn to point right at the station. That option may not be available to an apartment dweller. You might just already have the best you'll get if you're getting 10 channels already.
Posted on May 17, 2009
I have moved to ary from glasow and my tv wont work
you need to purchase a digital converter box to make an regular antenna work as everything has gone to digital HD even with a newer HD TV the box is needed to receive and decode the signal
Nov 23, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Says weak signal
Presuming you are already connected to a DTV box, welcome to the new improved TV service. I get it a lot due to atmospheric conditions ( rain, wind, etc ). Trees filter out your TV signals as well. Options : save the trees.. or relocate your antenna to get a clearer path.. or go to antenna tv.org & put in your street address, more reliable than a zipcode. Then, either with an old fashion compass or the "Smart Compass" app off of Google Play, realign your antenna to point towards the most stations you can. Mine just happens to be 204?.. or have a service company install an antenna rotor if you live in an area where the wind would blow it out of alignment frequently. Good luck. -DellTech1
Nov 08, 2013 | Philips Magnavox 20MT133S 20" TV
No ant signal
If you live out of town and away from pretyty much everthing there are few signals that you would get if any. If you live in town than the problem could lie in that you have a very very weak antenna or you have objects in the way of your signal. i.e trees
Sep 15, 2012 | Toshiba REGZA 32RV530U LCD TV
Can't get anything over antenna
Did you use an inside or outdoor antenna? An outdoor antenna rotated in the correct direction will give you the best chance of getting any signal. Look at antennaweb.org and tvfool.com for the channels in your area, the direction in which the antenna must be pointed and the type of antenna you will need to get them. Antennaweb.org is very conservative in the channel listings even with the assumption of an external antenna. Do you have hills, trees or tall buildings between you and the various transmitters? That will block your signal strength - remember digital TV is an all-or-nothing signal.
I hope this helps.
(antennaweb indicates that my location will only get 2 channels from a transmitter 10 miles away. With a properly oriented outdoor antenna and an splitter/amplifier, I actually get those + 3 from 30 miles away on several TVs without signal loss..)
Jan 04, 2010 | Dynex DX-L42-10A 42 in. LCD TV
I've just hooked up my converter box. I can get most channels with decent reception. However, I can't get my NBC affiliate. I've been told that I need a new indoor directional antenna. What kind shoul
Totally depends on how far you live from the station you want. I sell antennas, converter boxes, the whole shebang at my retail store, and you're not alone in your confusion :-) My best advice to you is this:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
May 22, 2009 | Toshiba 13A25 13" TV
How do I boost a digital TV signal?
No don't buy an LCD TV! I mean, unless you want to, they are nice :-) But you'll still have the same antenna issue. I looked up your antenna, if it's actually working just fading in and out, try an in line amplifier first (radioshack 1501170), and if that doesn't fix your issue, time to upgrade your antenna. It does get a little pricier, but do keep in mind the whole set up is good for 10-20 years. Before going back to RadioShack, go to this website:
www.antennaweb.org
Mar 15, 2009 | Toshiba 24AF42 24" TV
Some of my channels on my tv dont work with the converter box
www.antennaweb.org
Jan 27, 2009 | Memorex MVT2135 13 in. TV/VCR Combo
Converter box Help
www.antennaweb.org
Jan 23, 2009 | Philips Magnavox 20MT133S 20" TV
I bought an RCA 800 converter box and it keeps saying signal is too weak, so I bought a stronger antenna. It didn't work and the manual says I need a smart antenna. I bought the RCA antenna 1500. This is...
try this:
if the antenna is the kind that takes a power adapter to power try moving it away from the converter box and try changing frequeny on antenna this problem is usually for cbs channels...
Nov 12, 2008 | RCA Televison & Video
The instructions for our DTA800 digital to analog converter box for over the air waves for TV signals say since the signal is too weak that we need a SMART ANTENNA. What is that and what do you...
Hey boykinpierce,
The phrase "Smart Antenna" is often used to describe a multi-directional antenna or antenna array. These types of antennas are able to detect and automatically adjust to any changes in the TV signal strength you receive, and can generally be obtained through most major retailers. They primarily are used in areas where digital signals are weaker or somewhat inconsistent, and will attempt to optimize the signals they do receive before sending them to a TV or digital converter box.
Please keep in mind that while some DTV digital-to-analog converter boxes may have built-in Smart Antennas, this particular model (RCA DTA800) does not appear to have this feature.
If you're still not quite sure what to look for, please remember that you can always speak with a home theatre sales agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Televison & Video Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
