M
Matt McTaggart Posted on Dec 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lanier 5635 Sorter
I am getting a paper jam error with the sorter. There is no jam, but when I close the door to the sorter it displays error code sc726. I have unplugged the sorter and the errors go away. How would I either access the sensor to clean it or remove the sorter completly? FYI - I do not need the sorter.
  • Matt McTaggart
    Matt McTaggart Dec 18, 2013
    does anyone know how to remove the sorter?
quennie732
Level 2:
  • Lanier Expert 422 Answers
  • Posted on Jan 11, 2014
quennie732
Lanier Expert
Level 2:
Answers
422
Questions
0
Helped
236140
Points
775
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
3 Related Answers
Anonymous
  • 69 Answers
  • Posted on Nov 03, 2007
SOURCE: Lanier 7328
hi im jules_09,have you tried cleaning all the ruber roller?try cleaning all ruber roller then lubricate al bushing and gears.if there is still a problem check all paper sensor it can be cleaned with alcohol.just soak the paper sensor with alcohol then let dry after a few minute then install it back again in the copier.dont soak the paper sensor in alcohol while it is in the machine.turn of the copier first
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Jun 07, 2008
SOURCE: Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
chicagojoeco
  • 92 Answers
  • Posted on Jun 29, 2009
SOURCE: Sharp SF 2030 check sorter problem
follow the small holes on the sorter trays to the bottom and top there you will find the sensors that tell the copier that ther is paper in the trays make sure that they are clean and ther is no obstruction
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
The copier is displaying error code C06 (or C0b) 60. If I unplug the sorting tray (where the copies exit) the machine will make copies, otherwise it is frozen with the above error code and a red wrench? ...
I can tell from the code this must be a Minolta copier or made by Minolta. The CoB60 code is a sorter failure code. This code must be reset by opening, then closing the sorter. By that I mean if you have a 10 bin sorter that hangs from the left side of the machine then you need to release the sorter away from the machine then close it back. Same thing with the 20 bin which sits on the floor. Pulling the sorter away then re-attaching is the only way to clear this code. Now if the code comes right back then there is a mechanical problem which must be repaired. The 60 code deals more with the stapler in the sorter. You can try reloading the staples but that rarely works. It is either a jammed staple or a problem with the stapler itself.
If you need further info just reply back with your specific model and issues.
Thank You for using Fixya.
WheatlandServices
It says error code C0b63 what does it mean
All Cob codes on this series of Minolta copiers pertain to the sorter. Most all of the time you can simply open and close the sorter to reset the code. By open and then close I mean that the sorter must be pulled away from the copier then closed back.
Make sure there is nothing interfering with the movement of the sorter bins.
If opening/closing does not reset the code or if the code comes right back after resetting then the sorter will need service as dis-assembly/repair/re-assembly will be required. You can also unplug the large connector going from the sorter to the machine and use the copier without the sorter. If you have a 10 bin sorter that "hangs" from the side of the machine then you can leave the sorter attached and it will work fine unplugged. If you have the 20 bin sorter that sits on the floor then the sorter will have to be moved away from the copier if unplugged to prevent the machine from jamming. If you unplug the sorter be sure to turn the copiers power off before disconnecting the sorter.
Good Luck and Thank You for using Fixya.
WheatlandService
1helpful
Paper keeps jamming between the doc feeder and sorter, and fax does not work.
The Sorter is either disconnected or out of alignment. look behind the machine there should be a cable from the main unit to the sorter. Check it for connection, also make sure the sorter or inline with the machine. and all access doors are closed.
Hope this is of some help.
Ed
Error on the machine display is ch
If the CH is blinking the cartridge is not installed correctly. Remove and reinstall cartridge.
If the CH is on constant, it is a sorter problem. Check sorter for paper jam or bins out of place, and sorter connection.
Hope this helps.
Ed
2answers
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
1helpful
1helpful
4answers
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Lanier 7328
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
