Question about Dell Dimension 2400 PC Desktop
Dell E510 LCD. On/Off switch ? faulty
A friend took the LCD to pieces and checked every component. All fine except unable to check the on/off switch and the lead from that to the mother station. Any ideas if it can be peplaced and where I can get the parts and/or someone to do it. Belongs to my 17 year old who is in desperate need of a working computer as has his A levels in a few weeks.
from his worried/caring mum!!!
    President:
  • 814 Answers
You can find monitors like yours on e-bay being sold for parts. the monitor is a Dell E173FP Flat panel monitor. Plug this into the e-bay search engine and search for the lowest price one that will have the parts you need. You should have your friend help you with this.The switch should be on a switchboard. This is usually combination switching unit with more functions on the same board. You can buy one of the units and replace the board. You can also look at the switch board and find the part number. With the model and part number you can try to find it on the web. Use google and put in the monitor brand name, model number and the switchboard part number and see if you can find the part for sale by a parts distributor. You can also try to get help from Dell parts with the same information. I hope this helps you with your problem.
Posted on May 20, 2009
My tv works at my friend house, but doesn't work in my apartment. However all other electrical devices work at my apartment, model is (SLED5000)
Sounds strange indeed. All other devices; except the TV works fine with all power sockets at your house!! Just replace the power pin, at the end of the TV power cord and check. There is nothing more to check for you. It it too do not help you, contact any service technician. Electro help
Dec 01, 2014 | Sansui 50IN E-LED TV 1080P SLED5000
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
I shut down my Dell Dimension E510 last night and today when I pressed the on button, the computer wont turn on - not even an orange light on the power button. I tried disconnecting all connected...
Try this procedure! click here. After checking your power supply and it is working fine, put it back again into your computer casing. Next thing to do is to check your motherboard switch (power on). Look for the manual of your motherboard and look for the power on switch. If you find it then get a screw driver and short the pin using the screw driver. Be careful not to touch the other pin! But you have to check all the computer components to determine what is exactly the cause why it's not functioning. If it's not turning on your computer while you short the power switch on that means probably your motherboard fail. Other option is, in order to troubleshoot the problem of your computer you must have an extra computer with the same model and plug all your components there one by one to determine what is exactly the problem of your computer. Then you can decide what computer parts need to be replace. Have a nice day!
Dec 23, 2010 | Dell Dimension E510 PC Desktop
I have a Dell Dimension E510 and have had this problem in the past. My dell has been shut down for a few weeks and wouldn't power on. maybe a month later, i randomly checked it after being unplugged the...
Some power supplies have an independent switch to turn on the power supply before you can power up the computer from the front. Does yours have a switch on the back?
Nov 01, 2010 | Dell Computers & Internet
I have a Dell E510 that will not boot up. It has power and I get error codes 3 and 4. I have reseated the memory and replaced the memory to new memory and tested them one by one in the first slot. The...
Ok what you might try is get a new hard drive and install windows on there and see what happens. Also if you are able to before you try a new hard drive you should do a system restore and restore it back to the day that windows was installed.
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Want power pins on the motherboard of a dell dimension E510
Hi, i think u need to talk to dell support chat, they will give you more info, or else try them in parallel, i mean like terminate with a screw driver or u can download the service manual for this like Dimension E510.
Hope that helps
Cheers
Apr 27, 2009 | Dell Dimension E510 PC Desktop
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Fix graphics card on Dell Dimension E510
something on the motherboard may be damaged, if you replaced a power supply the motherboard really needs to be checked to see if there is any damaged components on it. my best guess is there are damaged components on it and you may need a new motherboard as well
May 09, 2008 | Dell Dimension E510 PC Desktop
Dell Dimension 2400 PC Desktop Logo
231 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
