Question about HP Officejet 5610 All-In-One InkJet Printer
The print spooler service is not available that's what it keeps telling me whenI tried to install my printer
I can't hook my hp printer on my computer they keep telling a printer spooler which I can't find
  • 26 Answers
Please perform the steps given below and check if the Print Spooler service is running or not
1. If you are using Windows XP then you may follow the steps given below
2. Click on Start>>RUN
3. In the box type Services.msc and click OK
4. On the right side of the window locate the service called Print Spooler
5. Right Click on it and then select properties
6. Make sure the service is started and not stopped
7. Also make sure the startup is set as Automatic
1. If you are using Windows Vista then you may follow the steps given below
2. Click on Windows Logo and in the search field type RUN and click it to open
If the issue is not resolved and if the printer is connected via USB cable then yo may try using the Print Diagnostic Utility which might resolve the issue.
For Windows XP and Vista 32 bit versions
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-3&lc=en&dlc=en&cc=us&product=441125&os=2093&lang=en
For Vista 64 bit versions
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56150-3&lc=en&dlc=en&cc=us&lang=en&os=2100&product=441125
Once you have downloaded the above utility run it and then choose the printer that you wish to repair and click on the Diagnose button
This will list all the errors and then click on the fix button to fix these errors.
Check the results
Vishwanath V U
Posted on May 17, 2009
MY PRINTER WONT PRINT, BUT WILL SCAN AND COPY
What is the operating system of your computer? Make sure the printer software is installed on your computer (available at http://bit.ly/g1FS2M) If you're using Windows, please check the Print Spooler service on your computer and make sure it is enabled. To make sure the service is running, follow the steps below:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 17, 2011 | Lexmark X4530 InkJet Printer
Dell 720 printer won't print.
The problem could be because of ONE out of FOUR problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 03, 2010 | Dell Inkjet 720 Printer
I have installed hp photosmart and get an error message '' restart print spooler error 1068'' I have tried everything but cannot restart my printer spooler.
go back to your services where you start the print spooler. open the dependency tab. there it will tell you what other services the print spooler needs to have running. check them and if any are disabled change them to auto and restart them. reboot and you should be OK.
Nov 05, 2009 | HP Photosmart 7450 InkJet Printer
HP Laserjet 1020 Spooler not starting
First uninstal old drivers then install again.
Then go to start menu then type in run "services.msc" then press enter
then you can seee right pane check there you find Print Spooler just double click on it then set
stratup type as automatic then click on depndancy tab then set restart the service .
then apply and ok.
Jul 15, 2009 | HP LaserJet 1020 Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Printer Spooler service!
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
pls do rate the solution if helped. thanks.
Aug 15, 2008 | HP DeskJet F380 All-In-One Printer
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
HP photosmart all-in-one 4100 series
The issue is with the print spooler. If the operating system is XP then click on start >> run >> type services.msc >> the services window opens, now locate the print spooler and right click on it and select stop(if it is started) then again right click on it and then click on start. Now the spooler service will start, then try installing the all-in-one software.
Aug 02, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
744 people viewed this question
Seeker5211
Seeker5211
