Question about KitchenAid Architect Series KEBC208KSS Electric Double Oven
Oven lights inop on Kitchenaid KEHC309JSS06 (bulbs good)
Both oven lights inop, both bulbs are good. Suspect transformer, but not sure where it is located...
  • t_massicotte Dec 18, 2013
    There is a transformer in the microwave section of the double oven (item #34 on the Cabinet and Stirrer Parts List), but I don't know if that transformer is the power source for the oven lights.
  • t_massicotte Dec 22, 2013
    Is there any way to read out any failure codes from the unit? I cannot find a service manual online.
SOURCE:
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Posted on Dec 24, 2007
  • 1314 Answers
SOURCE: Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Posted on Mar 30, 2008
aborcass
  • 2651 Answers
SOURCE: Oven Doors will not stay closed all the way
no real adjustment other then replacing the hinge assy's..
Posted on Apr 05, 2008
aborcass
  • 2651 Answers
SOURCE: can't change light bulb
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
Posted on Nov 20, 2008
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Posted on Jul 17, 2009
Oven light switch
replace the bulb with an appliance bulb found at any store that sells bulbs
Nov 18, 2013 | KitchenAid KEBC107 Electric Single Oven
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
How do I change the light in my double oven microwave KEMC308
the light cover at the back of the oven needs to be unscrewed. There is normally 2 or 3 little screws involved. Once it has been removed it's like any other light bulbs, unscrew and change. Make sure to put back the cover tightly in place or the light will burn when the oven turns on.
Mar 14, 2011 | KitchenAid KEMC378 Electric Double Oven
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
F6eo error code on our oven
Well most likely either the H.V. diode or H.V. capacitor is bad or worst case scenario the mag tube has failed it's a costly repair.
Can you hear the magnetron operate i.e. light dims, transformer has a louder hum?
post back some comments for more help....
Thanks
Good Luck!!!!
Aug 09, 2009 | KitchenAid Architect Series KEMC308KSS...
Oven light
Hi there it's possible that you are using an incorrect bulb in your oven....ensure on purchasing relacements that these are OVEN Bulbs (these are special bulb to operate at high temperature) ensure that the bulbs are screwed correctly and firmly into the holders and the glass cap is correctly fitted and secure.....
regards Sir Galahad
Mar 10, 2009 | DCS Large Appliances Built-In Ovens...
Can't change light bulb
Nov 16, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid built in oven KEBS107S
the machine has 1 year waranty on parts and labor thave them either repair it under warranty or give you a new one
Apr 10, 2008 | KitchenAid KEBC107 Electric Single Oven
Microwave oven light - KEMC 307
you ll need to pull unit out to replace bulb, 2 scrws remove side trim of oven, 3 or 4 screws remove trim under micro; above oven, 2 more screws behind that grill will release micro from supportthat should free it up enoug to slide foward 6 or 8 inches( the bulb is ontop of the cavity) good luck!
Feb 25, 2008 | KitchenAid KEMC307 Electric Double Oven
Go to PF when there is none
wshort, As long as you are sure the circuit to the oven is not the problem,such as drop in voltage, here are a couple of suggestions. Number one is that the electronic parts for this model have a five year warranty on them and you may want to call for factory service. Sometimes the connections on the main control board become loose or corroded. Try reseating them and see if the problem stops. If not I would suspect the control board power transformer behind the control board. There are two transformers, one for lights the other for the control board. The control board transformer should have the red and blue wires while the light transformer will have the black and white. The voltage could be dropping out here. Make sure that the wires to the oven terminal block are not loose or burnt. Since you are not receiving any error codes except for PF, Im not suspecting the board itself. Catriver...post back.
Dec 26, 2006 | KitchenAid KEBC278 Electric Double Oven
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
41 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
jdthefixer
Craig Butler
Craig Butler
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
