Question about Magellan eXplorist XL GPS Receiver
Have a magellan xl explorist and I think it was hit with 12 volts of power. Now the unit will not turn on. Is there a resistor or cap that i can check ??Any idears Thanks I connected my explorist xl with the wrong 12v adapter and now it won't power up. The Uk distributor, Manstbrite, do not want to know and are very unhelpoful. Can anyone help please?
  • 6,784 Answers
HI, i hate to be the bearer of bad news but, this Magellan is fried. this circuit board design what we call in the industry, micro cluster. this is a bad design because, if it is hit with a tremendous amount of unstable or inappropriate current, it will firy the entire board. the micro caps are not the issue here. the entire board(mother) is an integrated design and, it will need to be replaced at this time. all of the integrated board functions are fried.
You have two options. you can contact Magellan for a repair ticket and an directions to a local or nearby repair depot or, you can cut your loss and purchase a new unit. Unfortunately, there is no quick fix here. the Voltage spike has destroyed the entire board.
Posted on May 15, 2009
  • Michael Masters
    Michael Masters May 15, 2009
    Please rate and have a great weekend:)
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 | GPS
Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Mar 19, 2008 | Magellan eXplorist 500 GPS Receiver
We have a Magellan Explorist GC that we have had for only a couple of months. It freezes when turning on. The Magellan name comes up and the spinning compass thing, but then the spinning thing just...
I had the same problem. Was able to fix it as follows:
1. Turn unit off (pull battery if on/off won't respond) 2. Plug unit into PC with USB cable 3. Hold the menu key and the joystick in the "up" position and power unit on. Make sure you H O L D all three buttons as described until unit is fully powered on. 4. This should allow the unit to go into maintenance/disk access mode. Go to the Magellan website and download the newer version of the system (ver 1.4 as of this post). 5. Follow the install directions.
After doing this, my unit came back on just fine. From what I've read, ver 1.0 of the system has some issues.
Aug 10, 2010 | Magellan eXplorist GC Handheld Geocaching...
When powered up, unit only displays
May have gotten salt water in it and causing shorts, needs to be disassembled, cleaned and dried out carefully..... The corrosion film is almoner invisible and the small surface mount parts can suffer from small amounts.....
Feb 14, 2010 | Magellan eXplorist XL GPS Receiver
The zoom (+) key on my Magellan Explorist 210 GPS has become very sticky, and only works (eventually) if hit sharply. Is it possible (or practicable) for it to be repaired?
Yes it can be fixed but requires the unit to be taken apart. Most likely the rubber keys have lost the contact surface through use over time. Could be dirt on the pad surface...(inside)
Feb 13, 2010 | Magellan eXplorist 210 GPS Receiver
No drivers avalible for magellan Explorist 500 for Vista 64 bit
Windows 7 has a windows xp mode that seems to work. I have been using a VMWare image with windows xp for cranky hardware like my explorist xl.
Apr 05, 2009 | Magellan eXplorist 500 GPS Receiver
CAN NOT GET MAP ON GPS MAGELLAN EXPLORIST 210
try updating the firmware from the magellan website that fixed mine.
Oct 29, 2008 | Magellan eXplorist 210 GPS Receiver
My eXplorist XL is locked up
Error message at start-up reads: "Press ENTER to continue NAND, Press ESC to cancel". Either choice I seclect and the unit shuts-down.
"With you XL turned off press nav + power; then change the numbers in the box from 00 to 95 by using the joystick and then press the joystick itself; (ENTER), accepting what is proposed...
Either FORMAT or SCAN... LET IT RUN!
After turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. Your system will immediately start to re-set itself.
If necessary, in usb file transfer mode, reload the basemap in the directory background maps..."
The only difference is that I had to load my SD card in the unit for it to work during the FORMAT.
My unit is NOW re-booting back to normal!
Sep 02, 2008 | Magellan eXplorist XL GPS Receiver
Fault mesage on screen when first strat magellan 500
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
Sep 04, 2007 | Magellan eXplorist 500 GPS Receiver
GPS Logo
109 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
