Question about Kenmore 24032\24036 Top Load Washer
How toopen Sears top load washer Model 110 series. vbgeorges@verizon.com
  • hope888 May 25, 2009
    how do you replace the lid/door switch in a kenmore 110 series washing machine?  does the top come off making it easier to access???
  • 89 Answers
The top doesnt come off. the whole cabinet comes off.
on the lower corners of the console there will be 1 screw in each corner. if it is newer the ends of the console will be covered with caps.
pry them off from the top of the cap to reveal the screw
once screws removed flip open console. (wiggle and lift straight up, lean it backwards)
remove the small wire harness going to the cabinet (3 wire harness)
close to each side at rear under console there will be brass clips. use a flat blade screwdriver to remove.
once the clips are removed tilt the cabinet towards you to remove.
Posted on May 27, 2009
  • slypp187 May 27, 2009
    oops i forgot..
    lid switch just under cabinet. very easy to change
How do you install belt
usually direct drive if top load,no belt has a motor coupling,send model number so i can look up your model,sears kenmore doesn't make washers,they just put the name on it,say washer starts with 110. on model,then you know whirlpool made it.
Jun 24, 2014 | Kenmore 24032\24036 Top Load Washer
KENMORE 90 SERIES TOP LOAD WASHER WONT SPIN LOUD NOISE, SOUNDS MOTOR RELATED. WILL DRAIN SLOWLY CLOTHES ARE STILL WET AT END OF CYCLE.
does it agitate???. if it does not then you need the motor coupling. you need to remove the cabinet, yes, I said the cabinet, remove the pump,motor and you got to the coupling. replace all part in kit. reassemble and test. go to the website of sears parts WITH THE COMPLETE MODEL. and get the part. model starts like 110.xxxxxxxxxxx
good luck to you.
Feb 07, 2011 | Kenmore 15864/15862 Top Load Washer
I have a Kenmore Series 70 top loading wash machine that leaks. It is approx 12 years old, model 110.4767290 (canadian). It has a 2 inch crack in the bottom of the plastic tub. I tried filling with expoy...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The numbers following the 110 (which means it's made by Whirlpool) are usually 8 digits. Using the number that you provided, I couldn't find your washer on the Sears site. You will want to verify the number (usually by lifting the lid) and/or check for manuals / parts site from the following Sears site:
http://www.managemyhome.com/
Sears has replacement tubs (at least for my 12 year old top load for about $116.75 (U.S.) but you may be able to get one from Whirlpool for about the same cost. If you can get to the diagrams on the sears site. they often have "Manufacturer Authorized Substitutes) which are Whirlpool numbers.
FOR EXAMPLE, SEE THE SITE FOR OUR WASHER AND YOU'LL SEE EXAMPLES OF PARTS, DIAGRAMS AND COSTS.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26902691&pop=flush
Jun 22, 2010 | Kenmore Washing Machines
Where can I buy parts for my kenmore 90 series, specifically the piece on top that tells the washer to run when the top is shut. I have a Kenmore 90 Series 22992 100.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts, part numbers and Sears prices.
If your complete model number is
110.22992100See the following:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22992100&pathTaken=partSearch
I assume that you're talking about the Lid Switch.
Most local appliance parts should have the switch since it is one of the most likely parts to be replaced.
On the Sears site, you may see a comment in effect "manufacturers authorized substitute". If the first three digits of the complete model number are 110, the washer was made by Whirlpool and those are Whirlpool numbers. Again, usually available at appliance parts stores.
Jun 10, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore washer model number: 110. 82427130. I need the washers large selector knob. Where can I obtain a replacement?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.+82427130&pathTaken=partSearch
Look at the section / diagram for the Console and you should see the part you need with the Sears part number and price:
The "Manufacturers Substitute" is a Whirlpool part number and you should be able to find one at a local appliance parts dealer.
If not, you can order one from Sears.
Apr 08, 2010 | Kenmore 24032\24036 Top Load Washer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
What is the capacity of the Kenmore Model 110 Series 70 Heavy Duty Plus washer (circa 1985)? It is finally time to replace it. Sorry to see it go!
Many of the Sears parts sites for washers have a section where you can see PDF versions of their manuals. Look to the right of the main sub-components list and you may see it.
Oct 17, 2009 | Kenmore 24032\24036 Top Load Washer
Operator and parts manual for a Sears Kenmore washer 400 series
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The model number usually starts with 110.########
To the right of the sub-components list is usually a section where you can see and download PDF operating manuals.
If this is a basic Whirlpool / Kenmore top load, direct drive washer, following are two Whirlpool PDF locations.
The first is the installation and operations manual and the second is a parts list for their top load direct drive commercial washers, (consumer models use the same part numbers).
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 10, 2009 | Kenmore Washing Machines
Need to know how the control panel goes back on
Your model number will likely start with 110. and then a series of numbers.
A page will come up with a list of sub-components.
Click on the control panel section and you should get an idea of how it mounts.
Another good site is the Whirlpool installation and maintenance PDF for top load washers.
Sep 27, 2009 | Kenmore 24032\24036 Top Load Washer
Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
640 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
