Question about Dell Dimension 5100 (D51L1) PC Desktop
My microphone cable does'nt work it's a balanced xlr
L tried cutting the edge and fixing it but it won't work
  • John Viguers
    John Viguers May 11, 2010
    You did check in the audio devices to see that there is no X on the microphone mute box ?
    It is these little things that get me some times...
  • Dell Master
  • 13,433 Answers
If your microphone cord is cut and you can't repair it, take it to tv/video repairer they can repair the cord for you or buy a new microphone.
Posted on May 21, 2009
Rode Nt1a Beep Sound
Does the background sound get louder or fainter when you change the mic gain on your mixer? If it depends on your XLR cable, it may be radio interference, and you need to make sure you use top quality shielded cable, and that you're wired "balanced".
Jun 04, 2015 | Rode NT1A Professional Microphone
Sennheiser md 42 microphone not being picked up on camcorder help please.
This would require a special cable to work. The mic is MONOAURAL with BALANCED output and the camera is STEREO input. This means a special cable is needed and you would probably have to make it yourself as I haven't seen one on the market.Pin 2 of the XLR of the mic would go to BOTH the tip and ring of the plug into the camera. Both pins 1 and 3 of the XLR at the mic would tie to the sleeve of the plug to the camera. If you tried an XLR to 1/8 adapter, no audio would be heard other than from the buillt in mic.
Mar 08, 2013 | Sennheiser MD 42 Professional Microphone
After we switch from the auto to another manual mixing board the volume on one of the mics is decreased dramatically. all other mics are not effected. both boards are linked and we have a toggle switch to...
Check the cables. If one lead of an XLR-XLR cable is shorted to ground, 6 DB gain is lost. You haven't really supplied enough information regarding cables and model of the manual mixer for us to help much. Do check that ALL of your audio interconnections are BALANCED lines either XLR to XLR or TRS cables. Grounding one side of a balanced line reduces gain 6 DB. Try swapping mic cables and channels to test where the problem is in the system.
Aug 31, 2011 | Shure Distribution Shure SCM810 8 Channel...
Mic receives a lot of static and then cuts out. After a few seconds it seems to repeat.
This could be due to interference from other devices.
You could try changing to a different frequency (there are 20 to choose from).
Also move the receiver away from any strong electro magnetic fields (hearing loop amplifiers, CD/DVD players, TVs) or large pieces of metal and in clear line of sight of the transmitter pack.
Set up the aerials so that they are at a similar angle as the aerial on the transmitter.
Only use xlr balanced cables with good quality screening to connect the receiver to the mixer / amplifier. Keep signal cables well away form mains electricity cables as far as possible.
Wherever possible use balanced xlr cables on all other equipment.
Feb 13, 2011 | Audio Technica ATW-R11 Microphone
I got a cable to hook my MXL 990 condenser microphone to my computer and i get no sound. it wont record!!!!!!!!! its a 1/4 male to #-pin XLR female cable
Professional condensor type mikes require a phantom power source to work. That will be a balanced (read XLR) connection from source to preamp and the preamp must be capable of supplying the power. These units cannot be used in an unbalanced circuit (like 1/4" or computer mini-pin). Your best bet for the setup would be to get an external power supply box that can also convert the signal from balanced to unbalanced. That would be what the mike plugs into and then that plugs into the computer. You're probably looking at about 50-100 for even a cheap one that will work well. Companies like Sweetwater and B&H should be able to steer you toward a decent basic unit. If you happen to have a mixer (which is why you bought the good mike) then it may have phantom power for some of its mike inputs.
Oct 23, 2010 | MXL 990s Professional Microphone
Rarely used schure sm58 not used for a while but does not appear to work
Unfortunately if the microphone was dropped there is a good chance that the cartridge will need to be replaced. You should also check to make sure that the wiring isn't broken where the XLR jack is installed in the body and also where the cartridge is wired to the body. First and foremost you should try the mike with a known good balanced XLR microphone cable. Hope this helps.
Nov 29, 2009 | Shure Beta 58A Professional Microphone
I already have a 48volt phantom power and 2 balanced XLR microphone cables and does not work What do I do?
Make absolutely sure that your cables are indeed balanced. Use a volt ohm meter to test each pin from one end of the cable to the opposing end of the cable. No two pins for example pin 1 on one end to pin two on the other end should show a reading. If they do it means you either have a short or an unbalanced cable.Phantom power will not work with unbalanced cables and you can damage the phantom power supply by using an unbalanced cable with it.
Oct 30, 2009 | CAD Microphones GXL2200 Professional...
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Oct 15, 2009 | M-Audio Luna Professional Microphone
To connect a mono mic cable into a pabx with audio out what do you do with the earth cable from the mic cable?
your talking about using a balanced cable to hook-up an unbalanced item. no problem, wire pins 1 and 3 together as a ground and pin 2 carries your hot signal.
i'm not sure what a pbax is though! either the rules applies to everything that is pin2 hot.
Sep 17, 2009 | Audio Players & Recorders
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Dell Dimension 5100 (D51L1) PC Desktop Logo
88 people viewed this question
Alun Cox
