Question about InSTEP AR166 Stroller
Need new tires
I recently had tires that got holes in them and was wondering where to get replacements?
  • 50 Answers
You can order a replacement part or make a warranty claim by calling Customer their Service Department at 1-800-242-6110 or email them at info@instep.net For them to complete your order, you will need the name and model number of your unit readily available.
ive searched around for and found out that they do not sell replacement parts over the internet. i hope this helps you out.
Posted on Dec 04, 2008
When something goes shear through my tire; can that be patched up? Would I need to get a new tire if something causes a big enough hole? How are tire holes patched anyway? bryanflake1984| http://w
Do you have solid tires or inflatable tires. If they our inflatable tires and the hole is not too big they can hot patch them at a tire shop most of the time for free. If its a solid rubber tire and you have taken a big chuck out of it you will have to get a new. But I am thinking you have an inflatable tire. take it too the tire shop and see what they can do.
May 08, 2014 | NRS Hoveround MPV 5 - Used Power...
Rims. well i was wondering if i will need a tire balance and tire rotation for a new set of rims
If you have 3o-35,000 miles on your car, you may be due for new tires. Tires will ware out, you may have hit a few pot holes,or had a few flats. Manufacturers usually warrenty tires for new cars for about the same mileage I stated above. If your tires are waring well possibly you only need a wheel balancing. Take your car to a tire dealer in your area , and have them check for you. GOOD LUCK.
Sep 25, 2011 | 2009 Hyundai Accent
I recently bought a nixon newton watch and my crown fell off the other day. So now i can't adjust my time i was wonder can i replace the crown or do i need to get a whole new stem and crown?
if you still can see the stem near the hole of the watch, you only have to replace its crown. but if not you have to replace both. i hope i had been helped you.
Sep 01, 2011 | Nixon Newton Red Wrist Watch
Mazda 3 steering problem. will not hold straigth line
Did you hit a pot hole, bang the curb, or replace any tires
recently? I've had new tires to cause pulling left or right
and imprecise steering. If the car pulls to one side, try
swapping the front tires and see if the problem follows
the tire. Make sure tires can rotate in both directions,
some only rotate one way. You may need an alignment,
or something wrong with the suspension. Either case
a repair shop has to deal with it.
Feb 02, 2011 | 2004 Mazda 3
I have a 1997 Ford Escort that I recently put (2) new tires on the front. After the tires the vehicle started pulling to the left very badly. I had the tires switched in the front left to right, right to...
Yes loosening the top strut/bracket is needed to adjust the alignment, the rear should be fine unless there is damage to rear suspension compontents that need replaced, however for that vehicle just the front.
Jan 26, 2011 | 1997 Ford Escort
Very dull steering feel, wheel stays turned even as i slowly rev
Camber and caster settings are off. Have 4 wheel alignment done by a good shop and save your nice tires. Out of alignment will make steering feel heavy and wear tires fast!
Feb 06, 2010 | 2003 Nissan Maxima
What tires to replace first
Have the technician replacing the tires put the best 2 used tires on the rear of the cars and put the new ones on the front. You do your steering and braking with the front tires and if you were to have a blow-out, you want it to happen on the rear tires so that you can maintain maximum control with the good front tires.
Jul 24, 2009 | 1998 Ford Crown Victoria
Rough ride on 1999 ford explorer 4x4 XLT
if it was me i would check the shock mount at the top to make sure they are in good shape and checkout the tires to make sure you do not have a bad one or two and also check the stabilizer bar to make the bushings are not bad
Feb 27, 2009 | 1999 Ford Explorer
Buick Park Avenue - Low Tire Pressure Warning
What may have happened is that one of the tire pressure sensors was damaged, or the system was not reset.
The tire presure sensors use radio frequency to tell the module the tires presure and location. Replacing tires can sometimes damage them. The sensor is part of the valve stem. Use the driver info buttons to go to the tire pressure / location info. If you see " -- ", then the system cannot read the tires. Tech JK
Jul 26, 2008 | 2007 Buick Lucerne CXS Sedan
InSTEP AR166 Stroller Logo
191 people viewed this question
Top InSTEP Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Are you an InSTEP Baby Gear Expert? Answer questions, earn points and help others
