1.
If door
latched:
- Disconnect power from unit.
- Check wires and connectors from control to door switch, then from door
switch to control. If no damage to wires and all connectors okay, proceed to
step C.
- Replace door switch.
- Re-apply power.
- Press and hold any key down for 1 minute to clear F5 failure code from
memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
operation is correct.
2. If door
not latched:
- Check wires and connectors from control to latch switch, then from latch
step C.
- Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
F5 - E1
