Question about 2wire 2700HG-B Router (2700HGB)
How to test the above router
For the last couple of weeks my internet has seemed to slow down and become erratic. I am using a 2wire 2700hg-b router and wonder if it could be malfunctioning. How can I test it?
    Scholar:
  • 88 Answers
If your plan with your ISP is a CAP plan, make sure you are not over the CAP limit. Speed Test online: http://www.speedtest.net/
Posted on May 15, 2009
Slow Internet/Keeps Cutting Out
Hi try to test your internet connection by using a a eithernet cable and directly pluging into you router and computer. If your connection works fine with that connection then try to reset your router back to factory settings and use a new password just in case someone has been bumming off your wifi. also contact your service provider to have them ping your system, they can test the connection from their end.
Feb 02, 2014 | 2wire Computers & Internet
How many pc's can a 2wire gateway 2701hg-b
generally 4 at a time, but I don't know if there's really a limit, but you'll be sharing your bandwidth, which will slow down your connections.
To find out, open the prompt window and type the following:
ipconfig /all (notice the space) - hit enter.
Find the Default Gateway IP address.
Open Internet Explorer, and type the IP address above into the browser field for going to web pages. You will now be able to check the router yourself.
The ip may be something like: 192.168.2.1 - check it out.
Feb 13, 2010 | 2wire 2700HG-B Router (2700HGB)
The power went out last night and now the dsl box will not conect
Do a reset on your 2wire by pressing the reset button of it for 15 seconds while power is ON and then after that power it OFF for 10 seconds and then reconfigure your unit and check if its working already....
Dec 13, 2009 | 2wire 2700HG-B Router (2700HGB)
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700hg-b modem/wireless router, my problem is i get lag while playing xbox 360 online, i get red bar to none , while my friend have all green bar,in the tv screen,also my laptop lose signal...
yeah a better modem would be the easiest thing to do because it's clear that the one you've got is either not transmtting properly or is just the unit you'vee got has a fault in it
Oct 15, 2009 | 2wire 2700HG-B Router (2700HGB)
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Slow identifying 2wire686
Are you trying to use wireless? If so, do you have poor signal? I would suggest browsing to your modems interface. Type gateway.2wire.net into your web browser. Click on the Homenetworking icon. Select wireless settings. Type in your system password. Increase the power of your wireless setting located towards the bottom of the page. You can even try changing the wireless channel. Save and then retry to connect. Make sure you are entering the network key correctly.
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Slow internet speeds whith 2700hg-b
You said that you downgrade your net speed from 6mb to
3-800kb. If you have 3-800kb of speed it's very slow, i would suggest to upgrade again.
Nov 18, 2007 | 2wire 2700HG-B Router (2700HGB)
Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Sep 16, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
189 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
