Question about Kenmore Elite HE4 Electric Dryer
Getting an error code P 40
It just quit working and started flashing P then 40
  • Anonymous Mar 13, 2008
    I am having same problem, please help
Perfect Steam dryer control panel occasionally flashes and will not start.
If its an electric dryer check your outlet and power cord for bad connection.
Oct 06, 2015 | Electrolux EIMGD55I 27" Gas Dryer with 8.0...
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Getting error code E03-40. What does this mean?
E03-40 - faulty toner density sensor try the following press function the original size then 3..... your screen should display f1 service mode then press 8 then start now you should see f8 ..... now press start and scroll down to option 09 and press start now you wait till machine runs the process... after that you need to switch the machine off wait 1 minute and switch it back on
Jun 04, 2010 | Panasonic Workio DP-3520 Copier
Sub zero 611 refrigerator error code 40, freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 11, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub Zero model # 695 is flashing EC-40 error message. No ice.
When our Sub-Zero Model 650 quit making ice, and the SERVICE ICE lights started flashing, we called our technician who said, "You can pay me $178 for a service call or have another option - you have 2 seconds to decide. Oops, your time is up, I will decide for you!"
"Open the door and push the REFRIGERATOR UNIT ON / OFF message button; wait 30 seconds and push it again. About 95% of the time, the unit creates the glitch, and you are simply rebooting the computer. If that doesn't work, call me. I hate to take your money to come out to push a button."
IT WORKED! The warning message turned off and the freezer started cranking out ice.
Dec 18, 2008 | Refrigerators
Moutlrie I-40 IR flash doesn't seem to work
error 020000 relates to flash/flash charging...if new, take it back.I have repaired several by replacing the IR LED flash...easier fix than the incandescent units.
Nov 09, 2008 | Moultrie GameSpy 4.0 Digital Camera Deluxe
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
Error code C:31:40
After looking up the error code C:31:22, I saw all of the solutions for slapping the side of the camera. Slapped it 4 times, then the error code switched to C:31:23. Same solution... Whacked it 4 times, then the error code switched to C:31:40. Again, whacked it 4 times. Opened it up, turned it upside down and a rubber roller dropped out of the camera. I could see where it went, snapped it down on its metal peg and it works fine. Looks like its the rubber rollers that guide the tape that gets stuck. Before whacking it, make sure the RUBBER roller moves freely. Good luck!!!
Apr 14, 2008 | Sony Handycam DCR-TRV240E Digital...
Kenmore Elite HE4 Electric Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
