Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens
Problem for Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S...
There is no power to my Canon Rebel XT Digital
By dineen on Oct 16, 2007
There is no power to my camera.  I have tried a new battery and a new memory card and there still is no power at all.
Same Problem
Dec 21, 2008
-   My camera was dropped(?) or exposed to cold(?) and will not turn on at all. Camera store reccomended that I get a new battery, and felt that was the problem. I got a new battery, charged it, and there is still no power to the camera. I removed the smaller 3v, CF, etc. and it has had no effect.-   Guest
Dec 02, 2008
-   Stored the camera with the battery out and when I went to use it after several months it will not power on. I bought a new battery charged it and still will not power up. any one with the same problem that had it solved please let me know.
Thanks, -   lundyrandy
Nov 26, 2008
-   Camera was working fine...now just dead. HELP!-   Guest
Nov 16, 2008
-   Accidently thought I could use a 2cr5 battery and now no power. -   Guest
Oct 05, 2008
-   I have exactly the same problem. The solution to remove the both batterys dit not work. An other CF cart also dit not work...
There are no power on the camera. The batterys are complet full.
Mayby any one have an better solution......-   peter-w
Best Solution
posted on Oct 16, 2008
Very Helpful)
darntoothysa
Rank: Wiz  Canon Expert
Rating: 85%, 134 votes
Hi
If your camera is less than a year old then you should try sending it in to Canon for repair. If the camera is more than a year old you will have to take care of the repair yourself. If you take the camera to a 'camera shop' they will tell you its $200 to do the repair, but I know a place that will do it for MUCH cheaper Google: Darntoothysam com.
The fuse on the PCB (Printed Circuit Board) has most likely blown to save the board from being shorted and ruined. All you need to do is replace the fuse and you should be good to go! If you are skilled with fixing things and pay close attention to detail you can do it yourself.
If you don't want to do it, I know of a digital camera repair shop that can help you out. (Google: Darntoothysam) I don't think we have a no-power repair listed in the store, but we can get it added for you, no problem. We have a certified Canon, Nikon and Fuji tech do this repair for us, he has repaired hundreds of cameras for us over the past 5 years and does a great job.
If we can help with the repair, please let us know. Good luck from Darntoothysam com
Thomas
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 22, 2007
Helpful)
fast_typer
Rank: Apprentice
Rating: 83%, 6 votes
This happened to me today. The lens drive sounded weird - like off gear. Then it froze and wouldn't turn off without taking out the batteries. Then, it would turn on. Now it's ok. What I did was remove the cf card, lens, regular battery, and the little battery that is also in the battery compartment. I let it all sit while I did other things. When I put it all back together it turned on and I had to set the date but everything worked fine.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
peter-w
Rank: Apprentice
Rating: 75%, 1 votes
I have bring my camera to an reparateur in my country.
They find an serieus problem whit whater corrosion on the main print.
It look likes correct because i have 9 monds ago some water on my camera body.
Afther drying the camera works still fine till a few weeks ago.
The give me an Totall Loss report and aviceme to contact my insurance company.
So i send it now to my insurance company and i must wayt for the answer.
Now i have already an new EOS 400D body.
Afther the case whit the insurance company i shal try to open the camera and lokate the fuse.
Mayby he wil works again.......
Was this helpful?
Yes
No
Solution #4
posted on Nov 01, 2009
Not Rated)
yrkesmaklarn
Rank: Apprentice
Rating: 0%, 0 votes
Hi! I got a Canon rebel XT. For a month a go I droped it in water together with my Canon Ultrasonic zoom lens (75-300) in fresh water.... I took out the memory card and the battery. I dried it with a hair dryer every where for a week 1-2 hours a day.. and let it stand and dry in the sun for another week. Then I tried to turn on the camera.. the automatic lens did not work.. so I changen to my 18-55 mm lens and it worked perfect... so far so good. But after one days use I took out the pictures from the memo card.. and took out the battery to charge it again.. now is the camera totally dead. OI think its just a fuse in the camera... and the lens witch is gone. How much can it cost to repere it if I send it to you.. is it worth repering? and the lens.. is it worth to do a inner cleaning and repere it?
Was this helpful?
Yes
No
Popular Solutions for Canon Digital Rebel XT / EOS
1 Solution
3 Solutions
1 Solution
Questions and Unsolved Problems for Canon Digital Rebel XT / EOS
Do you recommend Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens?
Answer
Answer
I have an EOS 350D and have been using a Tamron 300mm lens for a couple of years without a problem.... (More)
Answer
after taking quite a few pictures we are getting a "your card is not formatted for this... (More)
Answer
When trying to use pop up flash error 5 comes up in any mode.Flash will not work.
Answer
every time I turn the camera on it will shoot by self and later doesn't wanna operate normaly.Can't... (More)
10 Other Users Have The Same Problem - Continued
Comment by lonearbor, posted on Aug 10, 2008
I have replaced both batteries and taken everything apart and let it sit overnight; still nothing.
Comment by dtwilhelm, posted on Aug 09, 2008
I have had my rebel XT for 3 years. All of a sudden it will not power up. Anyone with a solution?
Comment by Birchwoods, posted on Feb 28, 2008
My rebel is 4yrs old and all of a sudden there was no power. I did everything suggested for batteries changed and different cards. Nothing works it is just dead.
Anyone with an ideas?
pam
Comment by mgomery, posted on Feb 27, 2008
just got a brand new rebel xt with new, and charged battery and i can't get any power. what could be wrong?
Comment by Nicki13, posted on Nov 01, 2007
When I turn on the camera absolutely nothing happens. I have re-charged the battery, but still nothing.
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in Las Vegas, NV
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
