Question about Microsoft Windows XP Professional
Blue Screen on Windows XP
No hardware or software was installed on my computer, for the couple of months it was working fine. Yesterday when I switch on this message with the "blue screen" was displayed "a problem has been detected and windows has been shutdown to prevent damage to your computer". Pls help me on this ! What causes this problem ?
  • 433 Answers
Sometimes there are conflicts that cause errors to show up, I am glad you mentioned that no new hardware or software have been installed. That helps to rule out some things. At this juncture, if it only occurred once, reboot and don't worry. If you see it again, it will most likely tell you a error occurred at such and such a place and the computer will now shut down. If this happens try to write down the offending part or error and contact us again. However, it is always prudent to backup your computer. You can go in to the setup and look in you event log to see if it was a heat event that will cause your computer to shut down. Should this screen appears again, try the following:
Check to be sure you have adequate disk space. If a driver is identified in the Stop message, disable the driver or check with the manufacturer for driver updates. Pay attention to the video adapters.
Check for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Start up Options, and then select Safe Mode.
Tech Information:
*** STOP: 0x0000007E (0xC0000005, 0xF85F9AD9, 0xF898B7A4, 0xF898B4
please leave me a rating...
Posted on May 15, 2009
    Problem Solver:
  • 10 Answers
First enter into safe mode by pressing F8 at time of booting then in run command type eventvwr.msc and click the system link and then you may find which is causing error otherwise type "msconfig" in run command and click "services" and check hide all microsoft services nad uncheck all the services and restart the system you may find the soltion otherwise do post the error code at the time of bluescreen occurs not all code last four digits ok bye
Posted on Nov 17, 2009
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
My pinnacle instant dvd recorder freezes. it says burning error when i try to record, then my computer goes to the blue screen and restarts. i use vista. what is going on? why won't it work? the dazzle dvd...
The blue screen is referred to in the industry as BSOD( blue screen of death ) this is a stop screen that is built into Windows to halt on errors whether its a hardware malfunction or incompatibility or software conflicts. Your Dazzle could be faulty or the software is causing the halt screen. This is a major problem with Vista. I have changed most of my computers from Vista back to XP because my Dazzle and new video cam won't run on Vista but runs excellent on the same machine once switched over to XP. Good luck and fell free to Google BSOD for more info.
Jan 31, 2010 | Pinnacle Dazzle DVD Recorder
Problem loading Windows XP
You need to start windows in the safe mode, press F8 at boot up.
Remove al the drivers that you've installed on you previous computer system, usualy this is is a conflict between wrong drivers and your hardware.
If you can't remove the old drivers, reinstall Windows XP, do a clean install
by booting your computer up with the Windows xp cdrom, from the Windows XP cdrom you're also able to repartionate your hard drive.
First remove the old partition(s) en make a new one, the setup does then format your harddrive, after that you're ready to install windows xp on the new partition.
Jan 19, 2010 | Microsoft Windows XP Professional
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
Trouble with my new acer aspire desktop computer
Slow boot problems on any computers are due to 2 reasons :
(1) Hardware reasons and
(2)Software reasons
(TRY THE SOLUTION MENTIONED FOR SOFTWARE FIRST, IF THAT DOES NOT HELP, ONLY THEN TRY THE HARDWARE SOLUTION)
HARDWARE REASONS> if your system has less RAM (memory) then it can cause slow boot up issues,
SOLUTION FOR HARDWARE > I recommend you to check the amount of memory on your system., to check the memory on your system , click on start , then "right click" on "my computer " icon and select properties.. on the screen you will the the amount of RAM installed. I recommend 1 GB of RAM on a computer.
SOFTWARE REASONS> These can be a problem with the windows XP operating system.
SOLUTION FOR SOFTWARE> perform the steps as mentioned in the following links :
http://www.microsoft.com/atwork/getstarted/speed.mspx
(Click on the above link)
All the best
Have a nice day!
tc
Jun 13, 2008 | Acer Aspire™ T180 PC Desktop
Blue Screen of Death
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
193 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
