Question about Jabra BT150 Wireless Headset
Jabra BT3030 Device in Discoverable Mode?
I am trying to sink up my new Samsung Trance phone with a Jabra BT3030 Bluetooth device. How do I put the Bluetooth device in "Discoverable Mode?"
  • 26 Answers
Read the users manual(google is your friend)
But in case they drop support soon, turn the beastie on, press and hold the Vol+ and Answer Call buttons till the "on" light goes solid. You're now in discover mode.
Posted on Jun 01, 2009
How do I pair Jawbone headset to Samsung Galaxy S phone
Follow these steps to pair your iOS device:
  1. Turn Bluetooth on (from the Bluetooth menu on your iOS device)
  2. Put your Jawbone device into pairing mode (click the link below to access instructions for your device)
  3. Wait for your iOS device to detect your Jawbone
  4. Tap the Jawbone device name in the Bluetooth menu to connect
1. To begin, access your iOS device's Bluetooth menu:
  • From the Home screen, tap Settings
    • Tap General (for iOS 5 or older)
    • Or tap Bluetooth (for iOS 6)
Oct 25, 2017 | Cell Phones
Hi I have an iPhone 4 and jabra bt3030 worked perfect on my iPhone but in my iPhone I tap forget this device and the device was gone! now I can't find it again! what should I do?
    • 1. Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. It is the button that has an image of a telephone on it.
    • 2. Click on the "Settings" icon from the main screen of your iPhone.
    • 3. Click on "General" in your iPhone's "Settings" menu.
    • 4. Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
    • 5. Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
    • 6. Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
    • 7. Click on OK on your iPhone
Sep 13, 2011 | Jabra BT3030 Wireless Headset
My lg prime will not pair with my jabra bt3030 bluetooth headset
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra BT3030 Bluetooth Headset
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
Trying to connect jabra BT2080 to phone. says enter passkey?
  1. Bluetooth device A looks for other Bluetooth devices in the area
  2. In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
    You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
  3. Bluetooth device A finds Bluetooth device B
    Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
  4. Bluetooth Device A prompts you to enter a password (PassKey)
    With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
    On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
  5. Bluetooth device A sends the Passkey to Bluetooth device B
Jan 26, 2011 | Jabra BT2080 Bluetooth Headset
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Feb 07, 2010 | Jabra Bluetooth Headset with Adjustable...
I have a Jabra SP5050 hands free device for the car and have changed phones, I do I have to do to get it to pair with my new phone
Press and hold the button on the Jabra for 10 seconds until the LED starts blinking. This puts the headset in "discoverable" mode so the new cell phone will be able to see it for pairing.
If your phone prompts you for a pairing code, try either 0000 (four zeros) or 1234
Jan 23, 2010 | Jabra SP5050 Bluetooth Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
Jabra BT150 Wireless Headset Logo
1,055 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
