Hi All, I'm having a problem with my SGS GT-i9000. I was trying to root it to install a custom rom. Everything done correctly but when I rebooted the phone to enter recovery mode it shows broken coloe lines on screen. Then, I tried to get back into download mode but same problem there. & It keeps rebooting !! Plz Help !!
First, try calmly to enter download mode with 3 buttons combo. If you can't, then try to execute the script that unlocks download mode as seen in this page:
http://www.samsunggalaxysforum.com/samsung-galaxy-s-rooting/(fix)-release-3-button-combo-fix-for-samsung-galaxy-i9000/
Then, you can install another ROM, but be sure to install a suitable kernel.
Good luck
Ones your rooting fail...there is no way to recover but to contact your service centre....they have parent driver...there only they will reboot it with factory setting...never try to root device without proper knowledge and with proper driver...coz for different devices rooting method is different
so better not to go further by your own and contavt service centre asap
good luck
SOURCE: GT-i9000 sim registration fail
Well, obviously you've lost your CWM and root. Re-flash the kernel with CWM using Odin. The second thing is that you have used wrong image to flash. I'd suggest to restore old one or re-flash use proper image (include root/CWM)
SOURCE: Why is the SGS GT i9000 unexpectedly shutting down?
check your power save settings in the settings menu of the phone. it may be set to shut off @ 15-20% if you're using the advance task killer, you need to make sure these setting have been changed otherwise i think by default it's set to turn off @ 15%. hopefully this is your problem and is easily fixed. good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
It's Not Even Booting Up In Download Mode.
I Tried 3-Buttons Combo & all The Ways To Enter Download Mode But No Luck. It Just Show GT-I9000 Screen On Startup then the Same Broken Color Lines.
