Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Unable to Receive Incomming Fax's
I operate a home office with a Laptop, Printer and MCF-240C interconnected.  I have faxability (1 line, 2 numbers) and broadband internet access.  Prior to moving the office around I automatically received faxes with this configuration - no problem.  Now, incoming faxes are identified (diff ring tone), 3 rings latter ring tone stops, MCF-240C picks up the connection displaying 'Receiving'.  After several seconds I hear a click, display resumes to Date/Time etc, fax does not print... nor is it stored.   I have tried every concievable setting without fail.  I somewhat recall the setting 'used to operate' under MNL, but I cannot seem to programme it correctly.  Can you step me through the process please, desperate!
  • 5 more comments
  • Maeria Koligi Oct 16, 2007
    ...Saved.... no need to worry - problem has now been resolved!
    Thanks for your interest!!!
  • nance1 Nov 05, 2007
    I have a brother 2820 ,,the phone rings but no messages..the setting reads MNL..
  • rikkyboy Dec 29, 2007
    so what is the fix???
  • anakinra Jan 16, 2008
    i have the exact same problem, i hear the fax ringer, my fax will show receiving, then it just stops. how did you fix it? PLEASE HELP!! I really need my fax to be working for my business
  • Anonymous Jan 24, 2008
    I have a Brother MFC-240C all-in-one inkjet printer, previously I can receive and send faxes. Now I just cannot fax out or receive incoming fax.
    Pls help!
    Hani Ibrahim
  • Frankp1954 Mar 21, 2008
    I am unable to send or receive a fax. Incoming fax the machine show "receiving" but nothing is printed or stored. Outgoing the fax connects but shows as still "dialing" then disconeects with the message on the transmission log, "NG - poor line condition"
  • needful Mar 24, 2008
    My problem is a bit different. I have a new Brother MFC-240C and am unable to follow directions for setting standalone fax functions to manually send and to receive faxes at arranged times.Note: I am not using a dedicated fax line; a line to my phone has an a/b switch that sends one phone wire branching off to the printer. Perhaps I may not need the a/b switch arrangement if I could be certain that an incoming fax would have its own distinctive ring and not interfere with regular incoming calls. I should also note that I do have my phone company's voicemail and call waiting service, and am unsure if that would interfere with automatic receipt of incoming fax,.
  • 832 Answers
OK.
Posted on Oct 17, 2007
SOURCE:
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
How do I change my fax number?
I found you manual to download right HERE:
- as I´m informed, you don’t need to change you FAX number, as your fax machine will receive any call on the number you connect the machine to.
5757e4d.pngdo vote, if this helped you.
regards
/Teis
Jan 16, 2009 | Brother Multi-Function Center MFC-240C...
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Can't use the fax on my Canon MP 530
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough) if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly, So try plugging into the other port on the back, it's just next to the other port hope this helps
Aug 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
937 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
