Question about Garden
I need to know how the fuel lines should be connected for Ryobi 725r? There are three.
    Sniper:
  • 57 Answers
The line from the fuel tank that has the filter on it goes directly to the carburetor below the primer bulb. One line comes from the carburetor to the primer bulb. The other line goes from the primer bulb to the fuel tank. Primer bulb can be pressed to determine which side is pulling fuel (line from carb) and which is pushing (line to fuel tank).
Posted on May 15, 2009
How do you get the fuel line connected to the fuel filter nipple on the bottom side of the gas tank on the Ryobi 725r gas trimmer?
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 725r leaks gas from air filter and will cut out after starting up
This is a problem with most ryobi tools. From what i've read over time the gas lines shrink and need to be replaced. You'll need to replace both the lines coming from the carb to engine and the one connecting to your primer bulb. I hear there is a kit that contains both the primer bulb and fuel lines for this exact problem.
Apr 21, 2010 | Ryobi Garden
Need a diagram on how to connect the fuel lines back on a ryobi 725r trimmer
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Oct 01, 2009 | Garden
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
I have a Ryobi 725R weed trimmer. It starts and will run on 1/2 choke only. After about 5 minutes it shuts down, like it's out of gas but all fuel lines are full. Help??
Your carburetor is dirty. Disassemble and spray with carb. cleaner. Make sure the small screen is free of debris as well. Use a Den tek Brush, (http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in carb.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Ryobi Garden
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
487 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
