My konica minolta C364 when in 2 sided printing mode, will print one side normal and the other side on a quarter of the page, it is driving me crazy, i need help.
Does this happen with other files or programs pdf, word etc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
SOURCE: konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: Kinoca Minolta Di2510 Double-sided printing
Yes it can be done, if the m/c is having duplex unit.
