Question about Dishwashers
Main wash door won't open on whirlpool model du810swkqo recently bought new home with new (?) dishwasher but it looks like the main wash door (where the soap goes) doesn't have room to open. any suggestions?
  • debqualls May 15, 2009
    snap door that soap goes into won't open during cycle
  • Frank
    Frank May 11, 2010
    soap goes to a small round dish build into the door, with a snap cover.
    Genius:
  • 1,605 Answers
The cover is spring loaded. manually open the cover and pour some really hot water by the hinge, manually open and close few time, onec it is loose, put few drop of machine oil and work it again.
Posted on May 15, 2009
Why would a whirlpool adp6000ix detergent door not open
The dishes/pans you stacked to be washed may have moved and a handle is hugging the bottom drain preventing opening the door. The real main reason is like a car door breaks and it will not open on the outside well the door on dishwasher can break too. When its old then it telling you to update.
Apr 29, 2014 | Dishwashers
When we load our dishwasher and place the liquid gel in the door and then run a cycle thru, we open the door and there is the white gel still all over the silverwear and some still in the door compartment....
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 10, 2011 | Whirlpool DU1055XTSD 24 in. Dishwasher
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
SOAP DISPENSER DOOR MAY NOT BE OPENING STILL GOOEY SOAP AT END OF WASH
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Sep 24, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
No model number can be found on my Whirlpool built-in dishwasher. It has the term "Quiet Wash" on the front. It was brand new in 1996, installed in a new home but never used until a year ago.
If there is no number on the sides of the door edges,you can try taking the kicking unit off units below dishwasher and look at base plate of dishwasher if not there then you will have to remove unit and see if there are numbers on the top sides or rear of dishwasher.
Hope this helps.
May 09, 2010 | Dishwashers
Why does my new dishwasher (in a new home)smell
You have to leave it open atleast 2 hours after the wash. Atleast the door left half open.
Or the smell must be flowing from your main drain pipe!!
Mar 30, 2010 | Thermador DWU244 Dishwasher
The detergent door doesn't open
Please reply your exact model number so we can see what the door looks like.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
Main Detergent Dispenser does not open during cycle
check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwashers Logo
133 people viewed this question
Top Dishwashers Experts
