Question about Kenmore 93042 Gas Dryer
Kenmore 70 series,does not dry
Dryer does not dry,what ever setting you set, the burner comes on but it will only stay on for a short time and the flame will go out
  • jpchgo Jul 08, 2008
    The burner on my gas dryer will only stay on for one minute and turns off.
    Problem Solver:
  • 4 Answers
Check the vent pathway. Perhaps the theromstat is sensing high temp due to restricted air flow and kicking off.
Posted on Dec 21, 2007
Have a Kenmore Haevy Duty 70 Series Soft Heat model #96576200, I set the time push the on button dryer comes on to start drying but shuts off within 30 seconds. Any suggestions would be appreciated
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 27, 2010 | Kenmore 700 6972 Dryer
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
How do you turn off the dryer signal on kenmore 70 series dryer
On a 70 series dryer, the knob on the far right of the panel controls the signal. You can turn it left or right to set the signal to "On" or "Off."
If you've set it to Off and the signal still comes on, that switch that sits behind the knob is bad. It's the same switch that controls when the dryer starts. You can either try to repair it (by bending the contacts back into their original alignment) or replace it. A new switch is less than $10, and you can get one many places online, including from
May 20, 2010 | Kenmore 63942 Dryer
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Nov 22, 2009 | Kenmore Dryers
Kenmore series 70 dryer heats, but not enough to dry towels
1.- check thermostat limiter
2.- check for ***** lint and claen it , some times air does not come out and you need to dry for a long time.
Jul 09, 2009 | Kenmore Dryers
Long drying times model #11062712100
Try this and let me know what happens.
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 07, 2009 | Kenmore 73952 Gas Dryer
Heating on series 70 Kenmore Gas Dryer
suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Nov 26, 2008 | Kenmore 70172 Gas Commercial Dryer
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Kenmore 70 Series
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 93042 Gas Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
