Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will stop and I have to push down on the lid for it to start back thoughout the wash
Washer stops between cycles and I have to push down on the lid for it tocontinue
  • Whirlpool Master
  • 4,655 Answers
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer just stopped in middle of cycle
Push down on lid. The lid switch may be the problem.
May 16, 2009 | Washing Machines
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
The washer stops before the rinse cysle
That sounds like your lid switch. This switch is located on the top. Raise the lid, Looking down at the washing machine it is the little hole. If you push it down with your finger on mine it's grey in color. The problem is that the switch is not getting pushed down far enough. if you pull it down manually with your hand a little farther you should hear it click over and the machine might scare you as it starts up into the rinse cycle. You can purchase them pretty cheap online at any applince site.
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper washer issue
next time it stops raise lid on right side at edge of opening will be a small opening where lid switch is push down switch with pencil or something small enough to fit if it starts working replace switch ..if switch is not at that location may be under hinge left rear if that is the case ck hinge screws
Aug 20, 2008 | Roper RAS8445KQ Top Load Washer
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
113 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
